  • The final cut of the 9th episode of the Tesla Motors Club Podcast, featuring Chad Schwitters, the former president of Plug In America, is now available. You can watch it now on YouTube or listen to it on all major podcast networks.
Do these brake rotors need replacement?
Hey all. See attached. Rear brake rotors of my 2017 MX 100D. They were replaced one year ago. Is that premature wear? Thanks in advance for the info.
Might be worth checking the pads to check condition and to make sure there isn't something stuck between the pad and the rotor.
Tesla did it when I had brake service. They said to do several hard brakings to eliminate the buildup on the pads from low use. Which I did. I assume this wear happened before I ‘cleaned them’ with the repeated sudden stops.
ngng
1,521
838
Bay Area
the pad should be sweeping the rotor, it looks like the outer ring hasn't been touched. hard to tell by just guessing. just need to see your pad and rotor contact area. you can try some more stops to try to rebed the pads and clear up the rotor and report back
HenryT
1,093
978
Manchester
lf the rotors were replaced 12 months ago, and that is the brake service you refer to, then the uneven wear has occurred since then. As previously stated, the pads need removing and checking and if in decent condition with nothing trapped some hard braking sessions need to follow.
Rotors and pads were replaced 12 months ago. Then, 2 weeks ago, I had Tesla do the brake maintenance, ie cleaning. After doing the cleaning, the Mobile tech suggested I do the hard brakings to eliminate the buildup simple cleaning couldn’t deal with it. So, I assume the uneven wear happened before the cleaning. Note that this condition is identical on both sides. My ultimate question, will repeated use of the brakes deal with it or should I replace the rotors and/or pads again?
HenryT
1,093
978
Manchester
If Tesla saw them 2 weeks ago and didn't recommend replacement I'd stay as you are. See how they look, and more importantly how they stop after a few hard braking sessions when the brakes are warm.
