I'm seeing close to 400Wh/mi and a bunch of door bugs, but I still enjoy the car.I wasn't a disagreer (is that even a word?), as I don't even have my X yet, but one would assume that other people who enjoy their Xs aren't seeing 500Wh/mi ratings and a bunch of door bugs
Driving home yesterday, I had the fans on full blast and I was projecting about 112 miles left on my battery. I dropped the fans to auto and increased the temps about 2 degrees and that shot my estimate up to 162. So it looks like AC does add a huge drain to the battery, despite what some people say.
I've started using the % as well, but I was looking at the energy chart which lists approx miles remaining.Very interesting. I never set the fans manually. Also, I have a 5 seater so less A/C. I set the temps to 73-74 and auto. Consumption is slightly more when it gets to 100F versus 80F, but now massively different. Again, I only use percentage, never the estimated miles which I have found to widely wrong.
Love my X but the battery is just not big enough for its size. Surprising to me every time I see someone with a 60 or 75 kWh model x. I get it if you don’t drive much but the car is so grest we only want to take it on road trips... it needs a 150 kWh pack badly.
The energy chart estimate is based on the "average" power draw for the last (chosen number of) miles driven. As such, your A/C adjustments likely didn't have as much of an effect on that number as you think unless you keep it on Instant, but then it varies so wildly that it doesn't mean much regardless unless conditions are very consistent. So, unless you were using instant to get the numebr of miles, had TACC active with no lead vehicle, and were driving on flat land on a calm day, the almost certainly wasn't fully (or even mostly) attributable to adjusting your A/C settings.I've started using the % as well, but I was looking at the energy chart which lists approx miles remaining.
The only reason I set the fans manually is that when I wear slippers, my feet can get kind of sweaty and there isn't enough airflow through auto that pushes air to my feet. If I manually set the car to dump cold air to both top and bottom, it cools off nicely.
I definitely didn't believe that the AC drew that much power. That was under average though, not instant. They both showed about the same value when I was noticing the decrease.The energy chart estimate is based on the "average" power draw for the last (chosen number of) miles driven. As such, your A/C adjustments likely didn't have as much of an effect on that number as you think unless you keep it on Instant, but then it varies so wildly that it doesn't mean much regardless unless conditions are very consistent. So, unless you were using instant to get the numebr of miles, had TACC active with no lead vehicle, and were driving on flat land on a calm day, the almost certainly wasn't fully (or even mostly) attributable to adjusting your A/C settings.
