I have 16kW of solar and 6 PowerWalls. The monitoring app does not seem to recognize power changes (like 2 stage AC or oven turning on) on the non-backup leg.
For example, right now I have 11KW of solar being generated. The app says I'm consuming 1kW in 'Home' and 10kW are going into the PWs., nothing to/from the grid. Powerwalls are at 80% charge.
However, if I turn on both my large oven and the AC, which are both on the non-backup leg, nothing changes in the app. Power from solar, power to the 'Home', power to the PWs, and to/power from the grid stay exactly the same, no effect at all.
My theory for this behavior is (1)Home CTs are in the backup leg and can't 'see' the power to the non-backup leg or (2)solar can't get to the non-backup leg no matter what., or (3)some installation issue.
Also, even if the CTs are in the backup leg, wouldn't the PWs see that some solar was going to the non-backup leg as a reduction in their incoming power?
I quizzed the installers on this point and they said, no problem, as long as you have power from the grid then power from the solar and PWs will get to the entire house. You only lose power to the non-backup leg if the grid goes down.
Any thoughts on this are greatly appreciated
