I need to permanently power my wall connector. It's currently on a temporary 240v 30 amp circuit using a safe method.
My service is currently overhead and my meter is on the outside wall of my garage and the 200 amp main breaker is on the inside garage which then feeds to the main panel in my basement. Here is what I would like to do.
So I called a couple of electricians that Tesla had listed and they wanted over $14,000. Over fourteen thousand dollars. How? I asked one of the contractors how much I would save if I kept the service overhead and it was was a $2,000 savings or still $12,000.
This appears epic level unreasonable. I have been planning alternatives.
- Convert overhead service to underground, it is around 50 ft to the pole so everything outside needs replaced
- Install a double tap service to feed my existing 200 amp and just install a new 120 amp panel in my garage
- Install one 14-50 outlet about 3 feet to the right of where my service is located
- Install two 5-20R 120v 20 amp outlets
- Wire up my wall connector about 4 feet to the right of where the service is located.
