Absolutely not true. They may not have the range of adjustment, or may be more difficult to adjust, but they certainly are adjustable. Remove torx bolts and they can be moved.Anybody knows how to adjust the door on 2020 MY Tesla model3 ?
My left door is slightly misaligned when closed, it needs to go in a little bit more.
On my previous 2019 Tesla model 3 the striker was adjustable like in this video below.
On 2020 models the strikers are not adjustable any more!
Absolutely not true. They may not have the range of adjustment, or may be more difficult to adjust, but they certainly are adjustable. Remove torx bolts and they can be moved).
Mine were adjusted by mobile service while I watched.
Hmmm... my rear doors were adjusted. Didn't check the fronts as they were fine. Maybe that is the difference.That is great it worked for you.
On my car the striker bolts are fixed. If I remove torx screws I see the threads are fixed to the car and not movable. (Tried on both driver's door and passengers door).
Must be one off problem than.
Yes, exactly, and that piece of metal seems to be weld in to the car. I couldn't move it even after hammeringI adjusted the strikers on the rear doors of my 2020, loosened them and hit them with a rubber hammer. If you take the striker off it bolts a piece of metal behind the doorjam and that what you are tweaking
Ok you gotta post some pics here. What your saying is not making sense. The threads should be on the torx bolts, that’s how bolts work. Pics are like worth more than words or something like that. Not trying to be a smart donkey.That is great it worked for you.
the bolts themselves aren’t movable...it’s the striker plate that moves and then the bolts hold it in place. Post of pic of the strikers...the holes in the striker should be bored out bigger than the bolts...leaving room to move the strikers around. Don’t mean to sound rude, but looks to me like maybe you should leave the adjustment to tesla techs.
The striker holes are exactly the size of the bolt, so no much room to adjust. I guess threading a bigger hole a on striker could be a workaround solution.the bolts themselves aren’t movable...it’s the striker plate that moves and then the bolts hold it in place. Post of pic of the strikers...the holes in the striker should be bored out bigger than the bolts...leaving room to move the strikers around. Don’t mean to sound rude, but looks to me like may
I just adjusted my Model X Raven.
Usually the bolts are threaded into a plate and that plate slides around when all bolts are loose.
My Model X was very hard to adjust because the plate was fused to the body. I had to whack it pretty hard to break it loose. Might have been paint or something.
Otherwise, the bolts in the pic supposed to be movable, and they were on my 2019 Model 3 as I have adjusted them. I have tired to wiggle them bit now, seems they are somehow attached to the body. I guess it is a defect on my car
If the striker is fixed you should still be able to take the door panels off and adjust the latch from the inside.
