@Bollar
That's a gorgeous system... what panels/inverter did you go with?
If I read your bill correctly, Appalachian Power pays you zero for your excess power? Looks like you used 465 kWh, generated 662 kWh. The tariffed power rate (energy only) is 4.873¢/kWh plus 1.40785¢/kWh from a fuel surcharge = 6.28085¢/kWh total. It would be fair to pay you that much back, which would drive your bill negative. You need to drive your Model S more and use up that free power!Net 0 living, is it realistically possible?
Sounds like the math supports buying batteries to some degree, no?Correct AEP allows me to "bank" excess production so say in July I use 1300 KWh and make 900 KWh my bill will still be the minimum of $7.21 as I will use my spring excess. If over 12 months I produce more than I use, they thank me for my "donation". So my goal is to offset 90% of my usage.
I don't think so, as long as you don't over-size your solar array. Under the net-metering tariff, you can use the grid as a battery for free.Sounds like the math supports buying batteries to some degree, no?
I do not see how. I am getting a 1500 KWh "battery" for $7.21 a month. I am sure a real battery approaching that size would be 20X that. The other option is to over build the solar with a smaller battery but that too will not be inexpensive. For me the grid is a great storage option and with the SunnyBoy SMA inverters I can still get power when the grid is down but the sun is up.Sounds like the math supports buying batteries to some degree, no?
No, I don't think so. Under the particular tariff @dhrivnak faces, he gets to use the AEP grid like a battery for free, with power stored up to 12 months.Sorry, let me clarify my point...
My understanding was that people were dealing with "no payback" for "overage". In such cases, if the power folks set the limits too low doesn't it make sense to feed the grid until you reach your limit for payback and then store the rest into local batteries? It seems like there has to be an "overly limited utility" threshold point where it ends up paying for the batteries -- so essentially you get "power outage at night" backup for "free".
Somewhat related...
Plus (11 months, 3 weeks)
Minus (20.5 months)
Lapping chews through quite a bit more than autocross.Holy crap Brian... 401wH/mi?! how often do you go to autocross? :wink:
To me, the most egregious utility situation would be one where the meter never "spins backwards" and any grid in-feed would be "lost" from a billing perspective. In this situation, a smart battery charger that monitors the current on the mains just inside the meter would be a good solution. The ideal strategy would be to minimize the grid draw without letting it go negative by charging the batteries with variable current. Charging would only stop when the top of the battery SOC window is reached or the solar generation drops to equal or less than the household demand. Once charging stops, the battery inverters can feed power into the house to minimize the grid draw until the bottom of the battery SOC is reached, at which point all the power will come from the grid. However, I don't know of a specific solution that can do this.No, I don't think so. Under the particular tariff @dhrivnak faces, he gets to use the AEP grid like a battery for free, with power stored up to 12 months.
Suppose that he were to oversize his array to produce, say, 150% of his typical annual usage. What good would it do to have a battery storing the surplus? The utility will pay him $0 for it regardless of when he puts it into the grid. With this tariff, the optimal array size is to produce just below 100% of your annual energy requirement, and install no battery. If power outages are an issue, then install a CNG/propane backup.
They put the first rails up today.
Any details that you can share on the nature of solar installation on such a roof?
This is the exact same kind of roofing material that I have. I do need a new roof this year and am contemplating solar at the same time.
