Good to know!FYI, I came back from the Dublin Tesla and told me they are aware of the issue and there is a fix for the bump stop from Tesla China, Its not perfect but should help with the issue. I have one one order, apparently asians are more prone to this issue from what they telling me. I'm asian.
Wow! I just listened the clip and my ears are ringing! I have same sensation in my 2023 MS causing major headache and pain and it also happens while not driving. What was the fix for this?I have now on multiple occasions had the symptoms in the garage with car parked. Sunday I had the symptoms in my kitchen and walked out to garage to find ac running which was on other side of wall. My wife and sister came out and said they felt like the walked through a wall of pressure and gave my sister a headache. My brother came over yesterday with a special stethoscope. He also had symptoms and said he felt nauseous. I noticed for first time a very high pitch sound that I recorded and is below. It was making the noise with ac off. My understanding is the octovalve circulates coolant to battery even while parked. It sounded like the noise was coming from the circulating pump and my brother thinks its probably a bad bearing. Interesting thing is I recorded the day before with ac on, off, heat on, etc and didn't hear the high pitch then. I just got an appointment 3 weeks out(killing me on these) to have service center use their high tech equipment to record and send to engineering. Hoping this is the issue. Be careful with the clip volume below.
New video by Joshua Fuller
I have the bump stop on order as well with the new rubber knobs and supposed to be doing it tomorrow at my service appt. I am scared that it might make it worse as I do not feel the pressure that much anymore. I think I will tell them not to do the work. Like I said before, I do not want to have another issue after picking it up and could have just left it.FYI, I came back from the Dublin Tesla and told me they are aware of the issue and there is a fix for the bump stop from Tesla China, Its not perfect but should help with the issue. I have one one order, apparently asians are more prone to this issue from what they telling me. I'm asian.
Will do, need to go back for measurement and transfer photos.
They did it from the underside — took our wheel well trim and padded that way. Needed to take off the wheels to do it.
Here is one pic I got mid-way
Getting ready to head out the door and just seeing this now. I am not sure how much total I used. I think I had the thinner foam and I was applying on the outside of the wheel wells (the tire side). Not sure how much it helped. I would probably been better off just doing a couple layers of butyl instead.
Next week I'm going to do butyl on the wheel wells under the frunk. Probably won't do the foam there.
Did you mess with this at all? Did you just do the outside/tire area?There's not a lot of good places to put butyl under the frunk for the wheel wells. Most direct exposure of the front wheel well is obscured by the front suspension frame.
I just bought those sound fabric wheel well liners from AliExpress and put them on. No butyl. Slight improvement but nothing major and maybe not even noticeable for some.Did you mess with this at all? Did you just do the outside/tire area?
I have done the same install, not a lot of difference.I just bought those sound fabric wheel well liners from AliExpress and put them on. No butyl. Slight improvement but nothing major and maybe not even noticeable for some.
The tech should at least have it written down that he got sick. I would try another sc to see what they say and can try to help. Maybe cabin filter but I think it could be from the electronic rays like you said.Update : went to service center prior to my appt this coming Wednesday.
I warned them this sounds crazy and makes no sense but I get a terrible headache after being in the car even while sitting and not moving anywhere from 3-10 min. Was able to have tech sit and ride in car. He did not feel or hear anything. And truly tried to troubleshoot. He gave me his number to text him any evidence. Later that day he texted me saying he wanted me to know that after driving in my car he got a headache and brain fog like I described. But he cannot log this as there is nothing he can determine causes it .. or maybe it was coincidental. What’s baffling is that nothing is on in the car “car off” on drivers display. The only thing that is on is the wireless charger and the two led displays. I’m starting to think maybe a faulty display or it’s power supply so I bought an electrical signal , RD and EMF meter to test. This is getting ridiculous. Anyone have any ideas? Car has 600 miles on it and I’m starting to think I need to sell it. Keep in mind I had a model 3 for 3 years with no issues.
I would speak with an attorney first and see if you have a case before going to the SC. If you do not want to go that route and take a hit and sell your car, instead of dealing with the SC for them to acknowledge it and see how they can fix it. And I am not an attorney.EMF reader came today and it measures electricity , Rf and magnetic. i measured the EMF in the car today vs house and other areas. It seems the safe rating for emf is 3-5mG and that corresponds to everything I tested, except my car. The main display puts off 8+. The wireless phone charger puts off 10-78. Driver foot area puts off 15 and passenger 20. Center console arm rest 1.6. I’m no engineer so I’m just passing along info. I wonder how this compares to other cars. And are some of these readings out of normal operating range?
I feel the exact same thing. It goes away when i open a window while driving. Ear pressure is felt just by closing the door as if the car is indeed oddly air tight.Well the boominess is back. Not nearly as bad but it’s back to giving me a mild headache. I do notice it is worse at speeds around 30-40mph vs 60+. I can only guess that the hood is the culprit and or hatchback and the rubber stops are loose? The car just feels oddly air tight / sealed when sitting in it vs other cars. Like vacuum sealed. Maybe they went overboard in sealing it. Anyway let’s see what happens at my service appointment along with my 4 other open tickets, ugh. Never have I had this sensation in a car before… even flying 100k miles a year I don't get this feeling in a plane… bizarre!
