EarthX ETX900 12V Lightweight Lithium Battery Tesla Model 3
12V super lightweight lithium with built in BMS for the Tesla Model 3 installed using Taner Bosnali's 3D printed tray.
Easy 5-10 min. installation using factory hardware. No messing with aftermarket nuts, bolts or hold-downs. 23 lbs lighter.
The stock battery is 45Ah, while that one is 15Ah, about 1/3rd the capacity.
Does the car throw any errors for this? Seems like it would quickly identify it as a very worn out battery given it will have to charge it much more often.
No, no error code so far. The install was actually done back in July, 2021. I wanted to give it some time before my post to make sure I don't experience any issues.
Is this the kit that MPP sells?
Similar, but the MPP kit has a mounting bracket that's machined out of aluminum. This one has a plastic, 3D printed base that seems to allow the use of the OEM battery bracket.
The EarthX battery does not actually have less usable capacity. A lithium iron phosphate (LiFePO4) battery's capacity is almost 100% usable. Let's say it's 90% usable because you don't want to discharge it all the way. Then the EarthX has 13.5Ah usable capacity.
A lead acid battery capacity is not anywhere near 100% usable unless you want to permanently damage the battery. On a deep cycle battery, you could possibly use up to 80% of the capacity with a reduced life or up to 50% of the capacity for increased life. That would be 22.5Ah to 36Ah of usable capacity in the OEM Tesla battery if it were deep cycle, but I'm pretty sure it's not. For a regular lead acid battery, you do not want to use more than about 30% of it's capacity or it will decrease it's lifespan by a lot. On the OEM Tesla battery that would be about 13.5Ah of usable capacity. See how that matches exactly with the EarthX's usable capacity as explained above?
Tesla does not "look for" aftermarket batteries to pop up an error or cause problems. Tesla programs their charging system to only work with their OEM batteries, and aftermarket LiFePO4 batteries behave differently. Tesla notices the different behavior and thinks your OEM battery is on its way out.
In general, LiFePO4 batteries are good replacements for lead acid batteries because their voltage ranges are about the same for both, but not always. I installed a battery monitor on my Model 3's OEM lead acid battery last summer and have been watching it periodically. Mine never discharges more than 8%, so Tesla definitely does not treat it like a deep cycle battery and uses it more like a starting battery. I also noticed a change to how Tesla charges the battery towards the end of 2021, with an increased top-end voltage of 14.9V versus the max of 14.4V that I had seen before. The reason for the higher voltage could be due to colder temps (charging voltage should be adjusted for temperature), but Tesla changed the behavior with software updates so I don't know for sure. But that higher voltage likely causes some of the aftermarket LiFePO4 battery BMS circuits to disconnect it for being too high. This is what likely happened with the Ohmmu aftermarket batteries this winter where some people started having warning messages pop up on their Tesla. On the EarthX at least, the maximum charge voltage is listed as 15V before the BMS disconnects it.
One reason I don't think I would install a LiFePO4 battery in my Model 3 is because in the summer, the car floats the battery voltage at around 13.4V once it's fully charged. On a LiFePO4 battery, 13.4V is about 20% charged compared to a lead acid battery at 100%. If you read the EarthX datasheet, it recommends charging the battery at 13.9 -14.6V.
Reactions: KenC
By summer do you mean when temperatures are high? So if you parked in a garage that is not so hot this would mitigate?
No, being in the garage or not didn't make a difference to what I've seen (I live in Nebraska). The 13.4V or 13.5V float voltage is normal for a lead acid battery that if fully charged. Which happens on the Tesla on longer drives or if you use Sentry Mode or keep climate on. Anytime the car is awake, the DC to DC converter powers the 12v system and one the 12v battery is fully charged it will not be drained anymore until the car goes to sleep.
If this is true....
Why was it not an issue for 3+ years and then suddenly was after a SW update?
Why does Tesla charge to EXACTLY 14.60V, then check the float voltage afterwards, and only throw the error after the float voltage was determined? What error with a real LA battery can lead to it having a 13.6V float voltage, and this means the battery is LOW capacity?
My M3 throws errors with raw LiFEPO4 cells hooked to it with no BMS.
If this is true....
LiFePO4 cells and BMS don't behave exactly like a lead acid battery, which can cause Tesla's algorithms to think the battery is faulty. Tesla is only programming for their OEM battery and are not considering any other behavior or characteristics. And other software updates have caused issues in the past with Ohmmu batteries. I think it was in the fall of 2020. Ohmmu came out with a version 2 of the battery that had less capacity and different BMS programming to fix the issue. One year later, another update starts causing issues again. This time it looks like Ohmmu is testing out an addon module for their battery to fix it. They would try and make the BMS updateable to future-proof their battery.
Why would Tesla actively seek out aftermarket 12v batteries and tell you that they are bad? That would make no sense. As far as I can tell, there are a lot less Tesla Owner's that have installed the EarthX battery vs the Ohmmu battery. There are more people reporting an error message with the Ohmmu (but not all of them). I only remember reading about 1 or 2 people with the EarthX battery that had the same error message. Perhaps the EarthX battery BMS is a closer match for the Tesla as of now.
Reactions: dfwatt
So, for those wondering about the lithium choices now... It looks like we have ohmmu which has basically stopped selling their M3 and Y, .. and Mountain pass offer is $660 with a 15Ah starting battery,... and HPA ? with a plastic tray for $100 + u buy a Ex battery for $450, or, LithiumMoto Tesla line for $300 .
Is this correct ?
Just be aware that there's no evidence that those other options will perform differently than the Ohmmu. They are all way lower volume, and thus may just not be aware of the newer firmware issues. If there was a simple fix that the other batteries had figured out, I'd assume Ohmmu would be able to do it.
Reactions: Perscitus
Is this correct ?
The Mountain Pass Performance kit uses the same EarthX ETX900 battery. There are also the Antigravity AG-51R-RS or ATX30-HD, the ReLiON RB20-LT, and the NOCO NLP30 that would work. But as mentioned by gearcruncher, we have no idea if they would have the same issues as the Ohmmu battery but it is likely that they would.
