Factory Direct - Ohlins Coilovers are being released with ETA of July and taking preorders now. These will be the official kit from Ohlins and different from the Kit currently offered by Redwood. EAS is an authorized Ohlins retailer and Installer.
Find an Öhlins USA suspension products dealer near you.
www.ohlinsusa.com
Kits are priced at $3190. Shipments/Installs will be fulfilled in order received. Contact us to purchase a set or to be put on the waiting list.
Meet the revolutionary new Road & Track suspension for Tesla models. Backed by over 45 years of experience in advanced suspension development and global racing series, the Road & Track line showcases Öhlins’ ability to engineer the ultimate suspension system for driving enthusiasts.
europeanautosource.com
The Road & Track suspension for Tesla models is specially tuned for battery electric vehicle (BEV) applications and underpinned by cutting-edge Öhlins suspension technology. Öhlins’ patented Dual Flow Valve (DFV) technology transforms chassis control while sustaining a refined ride quality unsurpassed in the OE or aftermarket. Experience racecar-like handling without sacrificing comfort and safety, whether you’re driving to the office or crushing lap times on the track.
Ride height and damping control are adjustable to help you achieve the exact look and feedback you desire. Dampers can be individually adjusted through a wide range of adjustment options, with more than 20 defined clicks. Systems feature a monotube damper structure designed for heightened response, with strengthened inverted struts and aluminum body shocks that are lightweight and aid in cooling.
With the Öhlins Road & Track suspension for Tesla, you can expect a superior ride quality and elevated comfort over a variety of conditions and uses. The combination of premium features and options to fine-tune your performance result in the ultimate suspension package for daily drivers and weekend warriors alike.
The Features of DFV Technology
So what is DFV? It is Dual Flow Valve technology – and it sets us apart from our competitors. Only Ohlins has DFV technology on its road and track products.
With DFV, the dual flow valve gives the same characteristics on rebound as it does on compression, thanks to the damper fluid having a consistent path of flow in both directions. This means that the wheel and tyre can quickly and effectively resume their important position back on the ground, providing grip and traction. The new Öhlins R&T range uses DFV technology on every single fitment, making it the perfect upgrade for the enthusiast that needs comfort and agility in the one unit.
Features:
- DFV (Dual Flow Valve)
- Adjustable ride-height
- Fully rebuildable
- Corrosion salt spray tested (ISO 9227)
- Includes hardware and installation instructions
- 2 year Limited Warranty
Front:
- Conventional Shock Absorber
- Single bleed adjuster
- Spring preload adjuster
- Height Adjustable (approx. -5mm to -30mm lower than standard)
- Coil Springs (rate 110N/mm)
- Uses original top mounts
Rear:
- Separate spring preload adjuster
- Coil Springs (rate 120N/mm)
Models Supported:
Tesla Model 3
Tesla Model Y
