The guys at EmotorWerks (Dorian & Matt) came through and successfully built me one of their sweet charge stations using the heavy duty 70amp Clipper Creek Roadster cable I had acquired earlier on Craigslist. They were blown away with how thick and how much copper was in that cable which brought its challenges, but they overcame them Tested as well as picked up the unit last night and its working as well as looking good. One thing that's pretty sweet is the bluetooth and wifi connectivity. Its easy to schedule the charge as well as monitor it through many channels, so a high ease of use for sure which I for one will take advantage of. Plus not to speak of for total ease of use on the management side of things.
This box can run at 80amps if hardwired in, but I had them throw a 14-50 connector in so I can plug in play. I need to upgrade my home service before I comfortably can pull that much juice. We tested it last night and just as a quick test we were charging the Roadster fine, the VDS display was reporting 237Volts @ 60Amps so all looked good. I really have no need to charge higher than 30 amps unless I just ran an errand or need to do a long trip that requires more miles if needed on a moments notice. I typically charge at 30 amps since it has many benefits including being nicer to the grid.
I also saw Electric Terry there (EmotorWerk's shop) on his Zero. Never grows old seeing Terry and his welcoming warm spirited smile. He's testing and fitting some new quick chargers for Zero that Emotorwerks Dorian and Brandom who rides and races a Zero came up with. Very small footprint and fast fast fast! So great news on that front.
So all in all, very stoked on my new purchase. Its built like a tank, just like the Clipper Creek HPWC both inside and out. I love the steel enclosure too, that way you know its safe and gives an extra piece of mind while charging while you're away.
Lastly, everyone there at EmotorWerks loved and truly appreciated the Roadster and thanked me for bringing it up so they could personally see it. They're true EV lover's and enthusiasts for sure in which their high quality products and personalized service clearly do reflect.
