When dog mode is active, apparently sentry mode is turned off. I know I can manually re-enable tilt/intrusion after setting dog mode, but that can lead to false alarms due to movement in the cabin.
Under normal (non-dog) conditions, sentry mode is active and if someone brushes by the car or tries a door handle, sentry makes a recording (which is fine).
Is there any way to re-enable sentry mode? After all, if you're leaving your dog in the car that's when you'd want sentry mode the most.
