cwerdna
Here's a video I took of a setup but with BTC Power Fatboy chargers. Was to illustrate the cords, holster and and all for someone else.
Doesn't seem like it. Seems like the way to see them is to select the Tesla plug and then turn off all networks except for EVgo. The goofy part is that they'll show up with green markers (like level 2 stations) instead of orange (normally for DC (usually fast/semi-fast) chargers).Thanks @cwerdna . Do you know if these show on plugshare if I set the filter to "Supercharger" ?
Indeed. We Talk Tesla Connectors And Future Network Plans With EV Charging Network, EVgo mentions it as does EVgo Further Extends Nation’s Largest Fast Charging Network to Tesla Drivers (search both for navigation).Also a number of the EVgo stations can show up in the cars nav display these days. Was added a few OTAs ago.
I guess it depends on how badly someone needs a charge. If the supercharger is backed up, and you're in a hurry....But yeah, not much traffic otherwise.I'm concerned the EVgo won't see much use and regret support Tesla Superchargers when its the location that is wrong.
I suspect that EVgo will evaluate the success of the project to add Tesla plugs overall rather than focus too much on station-specific stats (although they'd be incompetent to not at least look at station-specific stats). I'm hoping this will lead to better integration, with direct Tesla support and faster speeds, rather than use of a Tesla CHAdeMO adapter, in the future. Time will tell on that, though. I've heard nothing -- not even rumors -- about how much usage these new plugs are getting to date. Also and FWIW, the last I checked, none of the EVgo stations in my area (Rhode Island) had Tesla plugs; the nearest was in the New York City area.I'm concerned the EVgo won't see much use and regret support Tesla Superchargers when its the location that is wrong.
I agree that this is probably what they will do. However, that is what concerns me as location is what matters. If you put charging stations out behind the garbage dump, you won't get as much success as if you put them where folks go and will want to go -- especially if you must charge high prices in order to keep your business going.EVgo will evaluate the success of the project to add Tesla plugs overall rather than focus too much on station-specific stats
This is why I'm concerned. If poorly chosen sites in other places don't pay off, EVgo's stupid beancounters may conclude that it isn't worth putting in Tesla connectors and stop rolling them out to sites where they may be worthwhile.the last I checked, none of the EVgo stations in my area (Rhode Island) had Tesla plugs
EVgo accounts do contain information on what car(s) a driver has -- at least, there's a database field for this information. It's been long enough since I set up my account that I don't recall if they'll let you create one with this information missing. It's also possible that the information could be wrong -- say, if an EV driver has traded in one car for another but not updated the EVgo account. Those caveats aside, if EVgo sees an account that's listed as being associated with a Tesla (and no CHAdeMO-using EV) charging at a station with a Tesla plug via the CHAdeMO port, then it's very likely that the charge is via the Tesla plug. Even if the data isn't 100% clear in all cases (like if an account has both a Tesla and a Nissan Leaf associated with it, or if it's nonsensical because it's out of date, like an account with a Chevy Bolt listed, but the owner has traded that in for a Tesla and is therefore charging using CHAdeMO), the data will provide them with some idea of how much those Tesla plugs are being used.I'm not sure EVgo can tell how much the Tesla adapters are being used. Maybe they would think that any CHAdeMO usage that has sustained charging rate higher than what Leaf can do would have to be a Tesla? My RAV4 EV can charge fast on CHAdeMO for longer than a Leaf too. So, both my cars (RAV4 and Model 3) on my EVgo account can take the 125A max for a solid 30 minutes.
EVgo seems to be adding these onto plugshare under the Tesla Destination charger category. So to find them on plugshare, select the "Tesla" plug. Toggle off all the charging networks, and just turn EVgo back on.
A distinction in color between relatively low-power (say, under 100kW) and higher-power (over 100kW) DC fast charging stations might be helpful. Letting the user set the cutoff makes sense, too.PlugShare should really show these sites with orange pins, rather than a green ones.
Slightly easier way to show the sites on PlugShare: Select the Tesla plug. Then set the Minimum Power slider to 50 kW.
This did not work for the EVgo with Tesla adapter that I ran across. It doesn't show up. I guess EVgo isn't advertising too well.All of the sudden the Minimum Power slider is only documented to work "Currently for CCS, CHAdeMO, Supercharger only". The slider disappears when none of those three are selected. But you can set both "Supercharger" and "Tesla" plugs, set the slider to 50 kW, and the relevant EVgos will show up in green.
Guess I didn't initially notice this nuance.
https://www.facebook.com/evgonetwork/posts/4230909943612580
We're on a roll! Our 400th Tesla connector was installed at an EVgo fast charging station this week, making it easier than ever to fast charge your Tesla! With hundreds in the works, a Tesla connector could be coming soon to a station near you! evgo.com/tesla
