Reid
Yeah, was probably in a bit of a hurry or couldn't find it. Point was, that company makes 'em.
Here's a proper link.
AC WORKS 25 ft. STW 10/3 30 Amp 3-Prong Dryer Heavy Duty Thick Extension Cord-1030PR-025 - The Home Depot
Curious if you've had any issues with this extension cord on different outlets... I purchased the 30 ft months ago and hadn't had the opportunity to try it until now. When I plugged it into my inlaws 14-30 dryer outlet, received errors on the M3 display:
Unable to charge with Mobile Connector
Inadequate outlet grounding - Try a different outlet
Unable to charge
Check charging equipment
It's possible that they have wiring issues but not probable, so I'm trying to debug this but I have limited access to outlets. I'm also having issues charging on 20 amp outlets with the evse 5-15/5-20 to 14-50 adapter as well, and wondering if it's because of this cord or my UMC. I want to debug as best I can before I schedule a service appointment, to avoid wasting anyone else's time
If you’re only pulling 12 amps, the charge rate may show 0 if you’re in the car with climate/stereo on and etc. Before we got the electrician out we were using a regular household outlet and it would only go up to 5mi/hr after we walked away and let the car lock and turn features off. Basically we only ever saw it in the app, not on the dash. (I think it might have gone to 1-4 on the dash if we were out of the car and watching through the window, but never 5, and it definitely showed 0 sometimes if we were still in the car with everything on.) We had to use an extension cord, but it was quite a beefy one for 15A.
If you have an RV park around, you could try your UMC with a proper 50A (14-50) socket and see if that works.
Home Depot currently $111.67 for 25ft or $92.00 for 10ftHas anyone sourced a reasonably price already made extension cord for a standard dryer plug. Will be visiting my parents in miami and we have an outlet in a utility closet but it is not super close to the where the car parks, so i would need like a 25ft extension.
Looking to get one without having to make it.
