I have an EO Pro Mini, connected with a DC leakage box of tricks all working perfectly at 32A.
However I have bought a new house (~20years old), which has a separate double garage approx. 10metres away from the main house. The garage does have power. I have not moved in yet and therefore unable to thoroughly examine the electrics but do know it is fed by a 20A fuse in the main consumer unit from the house. It has a separate fuse box in the garage with a ring main and lights.
If I was a betting man I'd say it was 2.5mm SWA cable feeding the garage - why would they install anything thicker 20yrs ago?
Anyone had similar?
Thoughts so far:
1) Run a new cable to the garage, which means digging up a driveway
2) Use granny charger at 10A
3) I think I can switch the EO Pro Mini down to 16A - may be able to run that off the ring main from garage (with the 20A fuse) and charge at 3.7kW instead. Would have to reduce fuse in DC leakage box down from 32A to 20A.
4) Install a 16A commando and use the granny charger
5) May be able to install charger on the house instead of the garage and connect direct to consumer unit in house - but think that will mean a fairly long cable to the car. Preference is to charge from the garage.
Missed anything? Naturally I would use an electrician to install anything - but thinking ahead of my options
Nick
Anyone had similar?
Thoughts so far:
Nick
