Check depart time is all switched off and scheduled charging is switched on, do you use the octopus app? Octopus won’t charge higher than the car is set for so make sure the car is set higher than the app.Tesla 7 kw wall conector
set in car
start time set in car at 0030
No precondition
Tesla wall conn is dumb
No other apps
Have you connected to it and checked there is no scheduling set. They are only semi-dumb in the UK after the scheduling functionality was added last year.Tesla wall conn is dumb
I have no idea personally, but are charging settings profile dependent?I added Mrs Mick to drivers profile two months ago and it started playing up then.
No other apps
bit drastic, but will eliminate software issues.
I think even the Tesla app will require you to log back in again too
Found the culprit. Charge Port Not Latched it’s not me, it happens too often.
