With a back up window 24 hours later: Launch Schedule – Spaceflight Now@Grendal does the OP need to be updated to show this info?
Why do you think that? Fueling time is well known, though there are 3 times the bits to go wrong. The static fire and previous launch give accurate timelines.Happily, this launch has a window of time. That is probably needed for the complexity of a Falcon Heavy launch. An instantaneous window, I expect, would be really tricky with FH.
First Heavy launch went to the end of the window due to high altitude winds, so yah bigger is better!I tend to agree—it’s more complex for sure, but I don’t think theres inherently more risk with sequencing/timing. That said, I agree with @Grendal too—beyond weather, being only the second FH launch there’s bound to be elements in the countdown that aren’t as well quantified as a F9, and having a little bit of cushion to resolve a minor anomaly [instead of aborting] is certainly a good thing.
Windows (or not) are basically an exclusive function of orbit, and more specifically the mechanics of getting into that orbit. LEOs and especially sun synch leos have little or no wiggle room on time of launch. Higher orbits and especially GTOs are much more forgiving.
First time viewing a launch. Feel The Heat secured. Driving down from the Philly area. Hope the weather holds, as earlier long range forecast was calling for scattered thunderstorms.
Bummed to read the pad is occluded from the FTH viewing area. Doubt the 200mm zoom lens I'm bringing is powerful enough at 4 miles, but should be okay a few seconds after ignition.
Since the LZ is 11 miles away, does anyone know what if anything of the landing is visible? Google maps show the Vehicle Assembly Building directly in the line of sight.
I was sure I had read somewhere that the 8th had been lined up as a 24-hour contingency. Cannot find that right now. Work...It showing April 7/8 doesn't mean it has a backup window 24 hours later. It is because the launch window goes past midnight UTC.
Looking at airfare now trying to decide if I can go or not.
Just a heads up for the hordes of folk flying in/booking hotels for Falcon Heavy, it could slip a few days. I prefer the Eastern Range dates (official), but it's worth the "heads up" tweet. Most of you know rockets can shuffle around on their launch dates by now.
