sunwarriors
You can also add a very small backup battery to avoid most of those issues
With the hassles of everything, if OP goes Enphase sunlight backup, either don't do ESS at all or at least do a small 3.3 kWh battery since like you mention, you still need their smart gateway anyways and having a small battery means you won't be able to backup many loads. Installers won't want to pull your loads due to more work, low $$ as well so you see more inflated quotes.
I've also stated in the past that getting only 1-3 Enphase batteries is probably not worth it neither. 2x 10kWh batteries (6 total 3.3kWh ones) used to run about $25k. Take fed tax credit and if you are lucky to get SGIP, you can see a ~$15k install which is probably close to PW pricing (even though it's still a bit more). I didn't pay much more than 2x Tesla PWs, but of course, the PWs have more kWh.
I'd like to see Matt Ferrell's reasoning for going Enphase. FranklinWH, a newer company has stuff good on paper, but they are new. Specs/features look pretty good though.
Here is his recent video:
