Front Fender Liners
Discussion in 'Roadster: Technical' started by Nvbob, Oct 16, 2011.
  1. Nvbob
    Nvbob Roadster 1256
    Just east of Lake Tahoe, Ca.
    Has anyone had an issues with the front fender liners drooping down above the tires? I was cleaning our Roadster today and noted that both front fender liners were hanging down.
    Has anyone seen this issue and if so how did you resolve? Thanks in advance.
  2. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    Whoa! That's unacceptable. I went right out and checked mine & nothing is hanging down.
  3. felixtb
    felixtb RsEU502,Sp+14274,XpEUSig4
    Lausanne, CH
    when was yours built, which number do you have? this could be caused by a change in supplier of a part, or just an anomaly. so there could be others built in the same time frame as yours with potentially the same problem.........
  4. bonnie
    Mine is 1194 (no problems), NVBob's is 1256 (problems).
  5. doug
    doug Administrator / Head Moderator
    That looks like it's practically rubbing on the tires.
  6. Nvbob
    Nvbob Roadster 1256
    We have 1256 (2.5) and the build date is March this year.
    Earlier this week we drove past some road construction where they were painting road lines here in Tahoe. Unfortunately, some of the paint splashed onto the mud flaps and bottom part of the car. I got 99.9% of it off using detail spray and a clay bar. While laying on a creeper checking the underside of the car and inside the wheel wells for more paint, I noted the front wheel fender liners hanging down. They are not close enough to the tires to impede driving or turning but it did surprise me. Luckily one of the techs will be working on the Alpine on Tuesday. I have sent the same photos to Jake and Adam (our tech) at Tesla.
  7. PV-EV
    PV-EV Member
    Alaska
    No problems with ours (#1237). We even have a 3/4 mile dirt road to get to the house from the highway. We drive slow (on the dirt, that is) and our Roadster is doing fine at 3300 miles.
  8. Dragon
    Dragon Member
    Italy
    #8 Dragon, Oct 16, 2011
    Same thing on the front right for my Roadster.
  9. vfx
    vfx Well-Known Member
    CA CA
    nc
  10. bonnie
    smart.
  11. Nvbob
    Nvbob Roadster 1256
    I discussed this with Adam (our local tech) and he explained they had changed the fender liners. The previous ones were stiffer and did not need any support to stay up in the fenders. The changed ones were not as stiff and they had seen some of them doing exactly what ours are doing. There is an easy fix - applying a prime coat and then some epoxy type glue to the inside of the fender. He explained they had very good results from that. So tomorrow he will be working on the Alpine (volume keeps jumping up and then down by itself) and applying the fix to the fender liners.
    Dragon, contact Tesla Support to get the fix.
  12. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Mine is doing the same thing. They're going to fix it next time they're out here.
  13. Nvbob
    Nvbob Roadster 1256
    Adam fixed both the fender liners and the Alpine. He put small brackets with a groove for the liners inside the fender walls and replaced the Alpine amplifier. He explained that both are well known issues that have documented fixes.
  14. NigelM
    NigelM Recovering Member
    Northern Virginia
    Mine already has those brackets, but my VIN is between dsm363 and Nvbob...interesting, I wonder if Tesla just did when they had my Roadster back for adjusting the window earlier in the summer. Nicely proactive if that's the case.
  15. Mycroft
    Mycroft Life happens
    On my boat
    Is it possible they changed liner vendors in the campaign to reduce road noise?
  16. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    I had the sound proofing added to my 2008 1.5. As part of it they replaced the plasitc liners with what seems like felt liners that I was sure would sag and not hold up. But after 1500 miles and a LONG drive through bad rain they seems to be holding up well. There are two clips that the liners are tucked above and if a clip fell off (they were glued on) or the felt came off the clip that would cause the problem I see in the photo's/
  17. Nvbob
    Nvbob Roadster 1256
    Clips seem to be secured pretty well. Time will tell.
    The Alpine fix was to first test the head unit and replace if needed (it wasn't) and then replace the amplifier module. Now, the volume control is better with smaller steps when turning the volume up or down. Also, for some reason, the FM reception is a bit better (not alot but better than it was).
