eledille
TMS 85 owner :)
pushing the car is more efficient than turning motion into electricity then back into motion.
Only if you can keep the engine revs and load close to its sweet spot.
The ICE is at its most efficient around the torque peak, and only at high load. Gasoline engines are particularly bad at partial load. I have no idea how they have actually done it, but it might for instance make sense to have the engine charge the batteries and deliver torque to the wheels at the same time to get better efficiency (high load), then switch it off later and use the generated electricity. The engine load from the generator is just as easily controllable as the output from a motor, so it's possible to perfectly blend generator load/motor torque with torque delivered mechanically from the engine.
If the engine will never have to run at speeds below e.g. 2500 rpm, you can also tune it more aggressively. So by disconnecting the engine from the wheels at a certain threshold to use it to power the generator at optimal load and rpm instead, you can choose an engine that is more efficient overall.
Seems to me that GM is trying hard to get the most out of the fuel.
