GM Chevy Volt
Discussion in 'Electric Vehicles' started by vfx, Dec 7, 2008.
  1. Skotty
    Skotty 2014 S P85 | 2020 3 P19"
    Kansas City, MO
    The Volt is a lot better than a Bolt. Sad to see it come to an end. It was one of a kind.
  2. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    Don’t try this in a Model 3. The solar panels will not fit!! Fortunately I had my Volt. 60B0A2B3-A764-413E-983D-B72BC600B5DF.jpeg
  3. JRP3
    JRP3 Hyperactive Member
    Central New York
  4. mattack4000
    mattack4000 Active Member
    My freaking Volt smells like burnt plastic whenever I use the gas engine. Gosh GM QC is almost as bad as Tesla
  5. Jeff N
    Jeff N Active Member
    How old is your Volt and how many times have you used the gas engine in it?
    I owned a Volt for 6 years. There is a noticeable smell the first few times that the engine is used as the new parts and any surface oils/dust etc. burn off from the heat of running the engine and exhaust. This can also happen if the engine hasn’t been used for a long time. This isn’t noticed on other gas engine cars because the engine runs much more frequently and for longer periods of time.
  6. scaesare
    scaesare Well-Known Member
    NoVA
    That depends on what your definition of is better is.
  7. Jeff N
    Huge numbers of people will be switching from gas-only cars to plugin cars in the next decade. Although many of these new cars will be BEVs there is still going to be a need (or a preference in some cases) for a transitional car like a Volt. I agree the Volt was an excellent car although it was perhaps a bit too small for some and the strategy of placing the battery in a tunnel in middle took up too much interior space.
    GM May yet bring back the Voltec design in the future. Other companies will have similar vehicles such as the Honda Clarity PHEV (and the BMW i3, sort of).
  8. mattack4000
    I have 6000 miles and gas was used maybe 1500 miles. I searched online already. Everyone talks about how it is break in and its normal. I am like WTF. There is clearly a plastic burning smell coming from the car when the engine is warmed up. The car's been very good, but this problem along with some small flaws drive me nuts. My Smart car doesn't have the same features, but at least I know it doesn't stink when I get in it.
  9. Jeff N
    Hmm. Try driving around in Hold mode for a few days so the engine runs like it would in a hybrid car although I would think that 1,500 miles of gas use, as you say, should have been enough. Even after the initial “burn in” it will still have a brief initial smell if it comes on after not being used for awhile (weeks or thousands of miles on EV only).
    If this doesn’t fix it then perhaps you have a slow oil or other fluid leak that is burning off every time the engine starts?
  10. mattack4000
    No freaking idea, I just know it is a burnt plastic smell whenever I run the car to full temp on the gas motor. I already have one car on jackstand, don't want to crawl under another one. Stupid dealership require a two weeks wait before they take it in
  11. InfinitiGuy
    InfinitiGuy Member
    Toronto
    Sad to see the Volt being discontinued. I have a 2017 (purchased in 2016) and it has never given me any problems. Over 90% has been on electric but I like knowing that I'll never be stuck anywhere with the gas engine as backup. My next vehicle will probably be a Tesla but it's too soon to replace my Volt.
  12. Mr X
    Mr X Future Martian
    Simi Valley, CA
    *Dolt
    Based on the pictures in this thread of my modded batmobile Volt, I highly beg to differ.
    Anyway, I turned in my Volt on January 24th. Saving up a little more for a Tesla. Soon.
  13. Big Earl
    Big Earl bnkwupt
    Springfield, VA
    The reason for my choice is because I want to be able to take longer trips without using any gasoline.
