comanchepilot
@267w/mi you can do the math yourself - if you are 100% SOC at departure - you have roughly 50,000 watts to play with -My avg watts per mile ended up being round trip were 267 and cruise control set to 80 pretty much the whole time.
Both driving out of town and coming back there's issues in Buckeye and Indio. It ends up taking about 10 minutes longer than the car states. Buckeye would only get 70 something kw and same with Indio. On the way home I made a extra stop so I also charged in Glendale and Eloy. Eloy had amazing speed.
I'm going again next weekend and wish I could bypass Buckeye, plus with all the construction there it just takes much longer.
If you want to arrive at a supercharger with 10% charge - then you have 187 miles to play with - so yeah you might have to stop in either Buckeye or consider Gila Bend - Gila Bend is never busy - and then you go to El Centro - and charge it there - and then hit up the supercharger in Temecula - none of those last two are usually that busy either - once you stop in Temecula and charge to 80% its only 70 miles to Anaheim and you'll have lots of local access to destination chargers and the DCFC - also - check the DCFC CCS stations from Electrify America - they cost basically the same and might give you a little bit higher charge rate =-
The 250 mile range of the Model 3 Standard is pretty limiting for long trips
