Help with diagnostic codes - 2013 60
Hi TMC community, need some help with understanding some diagnostic codes for 2013 60 with stability control problems.
Here are the codes:
ESP_d079_varCodeEeprom - no idea yet what it means? Probably related to electronic stability system/abs controller
GTW_w361_bdwCompromised - some issue with gateway probably?
ESP_d082_comSclVip405HsImpVIN - ni idea what it means
ESP_d060_axSensorFault - probably acceleration/impact sensor fault? How to identify which one?
EPAS_d076_KFC_DAS_TIMO - something with power steering?
EPAS_d048_KFC_EPB_TIMO - power steering related?
Any additional information/thoughts will be greatly appreciated. Thank you
pls see photos below
It is accident repair. The car sustained a minor hit at front driver corner. Parts that needed replacement: bumper cover, carrier support, subframe, abs module, break pump, airbags, some plastic pieces like nosecone and trim.
Yes, all visually damaged components were replaced, redeploy was done and completed successfully. I did not replace front impact sensors though, now I am thinking one of the errors might be related to faulty impact sensor.
Hi All, I just did factory redeploy one more time and everything seemed to be fine according to the log (attached). However I noticed from the log that "epas:0,esp:0" hardware IDs are 0. Does that mean the system does not see the modules?
Here is part of the log:
cid-updater:34434: do_handshake sid=3490 message=vehicle[vehicle_hardware_configuration_string]=tcid:6,tic:6,sierra:0,parrot:0,gtw:6,bms:39,di:22,pm:22,thc:8,dcdc:0,chg:9,cp:3,epb:2,epbm:2,ic:2,msm:0,ptc:0,rccm:0,tuner:0,epas:0,esp:0,ocs:0,tpms:16842752,bdy:0,ddm:0,pdm:0,lft:0,sec:0,dhfd:16842752,dhfp:16842752,dhrd:16842752,dhrp:16842752,sun:0,cc:0,umc:16842752,&vehicle[package_signature]=KxNgmlB0%2bZ07mm3nlDb1t0un7GRzvppo0hdDV3XyK2ArofEPvTKq%2fvN4%2bCAO1N9jJmy2Ea4Ik%2b%2bZClQydFUyDQ%3d%3d&vehicle[map_signature]=undefined&vehicle[map_country]=CA&vehicle[map_region]=EU
But in another place I see this:
Code:
gwmon Update esp.hex
cid-updater:17534: gwmon "11030000" => "11030000"   - skipping -     esp ready with UDS TP response
cid-updater:17534: gwmon succeeded.
What conclusion can be made from this? Is esp and epas system working?
Ok, just an update, the issue was fixed. For anyone that might stumble upon something like this in the future- the root cause was that some modules after replacement can not be tied to the car with simple redeploy. What needed to be done was to use Toolbox and “learn the vin of new part” and then do firmware upgrade, this is how I understood it. From what I could gather now, abs module, seatbelts and radar need this procedure, but there might be more.
couple of errors still left, would appreciate any insight regarding that!
Reactions: YieldFarmer
Here are the codes:
Hello. Did you get those errors fiz? how? thanks
