Aluminum really won't save a meaningful amount ofoney and will increase heat cycling concerns if you ever do run the circuit at 80amps.
My opinion on why Tesla says no aluminum on the HPWC is the expectation is the circuit will run 80% for hours on end and heat cycle. Aluminum's greater expansion can create issues with this.
A service line rarely if ever runs at 80% of rated and if it does not for long so the common use of aluminum there is less likely to be an issue.
