With your other cars? I wasn't aware this was even a thing since the cars need to move a short distance to take a reading/calibrate/relay this information accurately.
I can't help you with the app but I have mine displayed on the instrument cluster at all times, right hand side. Left side for me is energy graph since I'm often using nav so I don't want the tire pressure to disappear when the turn-by-turn comes up on the left side. Hold the right scroll and select "status" I think it is. This is should show the tire pressure of all four on the IC at all times if you do that.
Wow, didn’t know that was a thing. I’ll have to try that.
I simply swipe left below the car image. Tire pressure is one of the screens. Swipe the other way and you see trip statistics (or phone if you have a call or text active)
Which cars can you check the pressure by cellphone?
I believe a TPMS system will only show data when moving. The sensors turn off to save battery I think. Cars that display it for non moving cars are relying on memory (at least that is how my Acura acted).
Can you put air in them after the car sat overnight in the garage and it also works? Typical TPMS sensors go to sleep after 30 minutes of sitting. I think they only wake up to motion, but not sure. There are probably variations on different sensors.
