Probably no reason for it (and it may require processing power / separate stack that would preclude using FSD / AP during that time).Interesting idea and probably correct.
I see no reason why that couldn't be done continuously.
same hereStrange...other than the initial calibration in July of 2018, I have never recalibrated nor noticed an odd behavior that would have caused me to even consider recalibrating. I guess YMMV.
I thought there was some additional calibration required at some point. Maybe when Navigate on Autopilot was released?Strange...other than the initial calibration in July of 2018, I have never recalibrated nor noticed an odd behavior that would have caused me to even consider recalibrating. I guess YMMV.
Not in my case. I have never experienced any recalibration in my Model 3 since July of 2018.I thought there was some additional calibration required at some point. Maybe when Navigate on Autopilot was released?
Wasn't there a recalibration period when getting the HW3 retrofit? I'm pretty sure there was for me, also a July 2018 model (those all had the HW2.5 computer, so you'd need the retrofit before being able to use FSD)Not in my case. I have never experienced any recalibration in my Model 3 since July of 2018.
Yes, now that you mention it, this is possible, although if there was, it seemed very brief compared to the initial calibration (which was 30 miles or so). I think the recalibration may have been done before I got back home (and I'm very close to the service center!)Wasn't there a recalibration period when getting the HW3 retrofit? I'm pretty sure there was for me, also a July 2018 model (those all had the HW2.5 computer, so you'd need the retrofit before being able to use FSD)
Got it. Thanks. It didn’t take long. I wanted to drive on the freeway, but it finished before I got there.When you calibrate or recalibrate the cameras, FSDS is disabled by default, and the system returns to AP. After calibration is complete, including any additional calibration for FSDS, you will need to pull over and park the car, then go into Settings -> Autopilot and set up your settings again for FSDS.
