All Model 3 doors, front and rear, require a push of button to unlatch that pushes door out by <1 inch like pulling the handle on any regular door, then it's manually pushed outwards to open. They do not open on their own. If they did in the past for you then it was an anomaly.
Honestly I don't remember how I open my door because it's second nature at this point but I think I hold it while applying force with my elbow until it's open and it all usually takes maybe half a second.
Here is my original post:
"and sometimes I would need to simultaneously push the door when pressing the button to open it, just like I do with the rear seat doors."
So to clarify, the front doors buttons "sometimes" need to be held down while pushing door. The rear doors "always" required that. That is why I compared the front doors to the rear ones.
It takes a troll to see a troll. This low post count noob is messing with you all.
mhmhsh - figure it out yourself. If you can't operate the doors, then you don't deserve to have a Tesla.
Honestly it sounds like OP has an intermittent issue with his electronic door latch release on his car...
I would suggest make video of problem occurring in your car, then go to SC, if they say your car is fine, ask to see a loaner or demo car behave the same way.
As I mentioned before, it seems to me that your car must be different than all of ours, because unless you retract the "my door used to open 45 degrees" statement, your experience with your car does not match anyone elses model 3 that I know, have sat in, or even read about (and yes I am focusing on the 45 degrees statement because it implies that there is some power to the opening of the doors, which there is not in any model 3 I am aware of.. its absolutely relevant. Its the most relevant part of your statement).
I've always defined a door as being the portal through which one enters or leaves a given space. On the other hand, a trunk / engine compartment / frunk / bonnet / boot is covered by its lid which sometimes goes unmentioned (as in 'close the trunk', 'shut the frunk', et al.)What is 'rear seat door' ?
Do you call the front doors as 'front seat doors' ?I conclude 'rear seat doors' to be the doors nearest the rear seats.
I actually think what you are describing as intuitive is the opposite. When people open a regular car door they don’t pull and handle and then push, they perform the action simultaneously. The fact that their is a button dose t change the operating procedure required for opening a door. Just because there is a button involved dosent mean you have to push the button and wait. In fact slipping you hand in the door pull pushing the button with your thumb and pushing the door open in one motion is a very fluid and natural action. No one pushes a button and sits there unless they are used to a ‘20’s hot rod with custom pop doors.But I think it does matter. If holding the button while simultaneously pushing the door is required, then you would have to tell your passengers every time (think of ride sharing) because that is counter-intuitive. However, if you could just press the button and release it (like you normally do with any button), then pushing the door to open it, is intuitive.
The thing is, I have experienced both in my model 3 doors. Sometimes, just pressing the button and immediately releasing it allow me to push the door and open it, and other times that does not work unless I hold the button while simultaneously pushing the door. I have just had my first visit at the service center for this issue and got conflicting answers from them. So I wanted to know the correct/expected behavior from the owners here.
Yes, I got that I have to push the door either way. I am just asking a different question than the one in the topic of this thread.
Thanks!
Why would a car be designed to have its doors swing open on their own to 45 degrees? Just suppose that happened when you got yourself into a tight parking space and you door automatically swung open into a car next to yours. You might then dent the other car and perhaps, your own. You always need to be able to control how much the door opens in order if necessary, to squeeze out of your car without any damage.These are two correct statements about my car:
- The two front doors "used" to open wide in the first few weeks. I don't retract that statement. When that changed, I thought it was a firmware update. As others pointed out, that could have been due to gravity working on a non-flat surface. Right now, they don't open wide as before.
- The buttons on the two rear doors used to always need to be pressed and held down while pushing the door, while the two front doors did not require holding down the buttons. I thought it was a design thing. Lately, it became an intermittent thing on all four doors.
But thanks for confirming the correct behavior.
