Don't pay attention to Timothy, they obviously haven't read this thread to understand the methodology used to get the BMS to re-calculate the battery capacity more accurately.
Sure buddy, just that I was actually explaining how the BMS calculation works months before this thread, and you were pushing disagree on every time if I remember correctly
And now you are the first one to "explain" the methodology. If I look back at your posts I will surely find one where you say to read the manual and keep it plugged in...
You are supposed to let it sit, and sleep, at various different states of charge for hours. This means you have to make sure that everything that could keep the car awake is turned off. (Things like Sentry mode, third-party apps that keep the car awake, etc.)
You don't have to let it sleep at 90% for hours that is certain. Since you still don't understand how the calculation works let me explain - it is pretty simple. The car measures voltage while charging, but it also double checks the voltage at various SOC when sleeping,this part is true.
But since the car knows the voltage at 90% when it charged to 90%, you don't have to actually leave the car at 90% - the car already knows that.
So the car does this:
Start at 10% - ok, we are at Vx and Vx is normally this kWh
End at 90% - ok we are at Vy and Vy is normally this kWh.
Let me deduct kWhend - kWhstart and get kWh added.
Then it cross checks inside the BMS what the kWh added should be and calculates the kWh difference and deducts it from the range.
There are actually apps that do exactly that on your phone, Google them. They measure the mAh added at different state of charges.
The main problem with degradation in these threads was not tso much hat they didn't let the car sleep - that is the smallest problem. The main issue is they were simply charging 70%-90% consitently "because the manual says so" and when I pointed out that problem, people like yourself told others not "to listen to me"
By charging to 70%-90% the car can't figure out where it is since the Voltage in that range is simliar. That is the main issue, not sentry or leaving the car awake (which is also problematic, but not the main problem)!
If you keep on charging 10%-90% and disable sentry, without bothering with anything else, you will be fine.
