I have finally decided to see how fast I really can go at the Dragstrip. The last Test and Tune of the season is next Saturday and I want to make the car lighter.
I tried removing the front passenger seat. I got down to where there were only two cables attached to the seat but I couldn't figure out how to remove the connections without damaging them.
I couldn't get the passenger seat cable nearest to the center console to detach. It is wedged up against some hard plastic on the seat and I just couldn't figure out where the release for that connection is. Have any of you completely removed the passenger seat? How did you detach the numerous cables?
I also had trouble with the cable/cables that appear to go up into the seat back. I have aftermarket seat covers so I couldn't access the seat backs. Are those connections difficult to remove?
Is there anyway to disconnect the entire wiring harness in the car itself instead of removing it from the seat with the dozen or so connections? Is there a single connection that you can undo and remove the seat with the wiring harness still attached?
Any videos or instructions on how to get the Front seat out or any of the seats would help me. It needs to be non destructive. However, I could use help removing the seats or any of the Frunk components too.
