Q1 s there a simple way to reset the back door lock. It won't open from the outside nor from the inside. The door locks somewhat less frim as the other side but it won't open. Tried to lock and unlosck several times but to no avail.
Q2 Anybody with additional info / instruction to remove the the lock (could only find replacement of the front door handle see below)
Situaton : I wanted to pick up a rear passanger. I stepped out. Pushed the front of the handle of the back door with one vinger of one hand to unlock and engage the auto open/close mode. I used a vinger of the other hand on top of the slightly lowered window to open the door for the passenger. Bad idea.
My vinger on the door handle slipped and automatically the door & window auto closed and my other vinger got seriously stuck between the closing window and the door frame. I was able to pulled the brused and bleading vinger out but since then the door is jammed. Previous cars the window would auto stop. Tesla widows mechanism are not so smart. Lucky that it was me and not the childeren I picked up.
Info I could find was on window & doorcard removal and doorhandle front.
Anthoer video shows how to remove door panel and window ( look at full video first before starting f.i. marking the window bolt & NOT to remove the regulator info comes later)
