There are NEMA plugs that will handle the current. You just have to know what to look for. (think camlock) I would be careful as to knowing what you are doing. As they say these are rated for greater than 50A. (more like +150A)
HPWC is made for a hard wired connection only.
Thinking about this, being a hopeless DIY I could add a plug, but what would be the point? The Universal connector's capacity is a 50 amp circuit with a 40 amp draw. Those are the specs for my current outdoor curbside set-up for my Volt, which I'll be using for the Model S. Even if I added a plug to the HWPC I'd gain nothing over the Universal connector in terms of charging speed/efficiency for the Model S, as it would operate on the limits of the 50/40 set up I have now. And if I upgraded the wiring and breaker to handle 80 amp draw, it would be for naught, as there are no NEMA plugs that I can find which handle more than 50 amps.
What I am suggesting is a plug-in version may be made available by Tesla; Leviton already has a wall mounted unit that plugs in. The info sheet Leviton provides is a good primer on EV code: EVSE Fact Sheet: 240 Volt Home Charging Station | Leviton Information Exchange
The main benefits of a plug-in vs hard wire wall mounted connector aka HPWC are the following:
No separate service disconnect required
Cost to install should be less as fewer parts to install. (no separate service disconnect and extra wiring associated to connect the switch to the HWPC)
Upon sale of home; unit can be taken with you. (Normally, hardwired items are considered part of house unless specifically excluded)
Electrical Permitting is "over the counter" vs. submittal of detailed drawings. (this varies by jurisdiction so maybe a draw)
The main drawback of a plug-in unit vs a hard wire unit is less current draw which = longer charge times. However for those that give aesthetics and the above benefits a high priority, a plug-in wall mounted connector may be preferable to a hard wired wall mounted unit or the UMC.
You are mostly mistaken:
1. Anything over 50 amps would likely require a service disconnect if a plug was involved
2. The cost of the receptacles themselves would be as much as the EVSE!
3. On sale of the home you can still take it with you. List it. Dismount the unit, turn off the breaker, remove the wire nuts. secure the wires, place a cover plate and done.
4. I'm not sure that there is much difference in permitting for 100A service plug vs hard wire.
I'm sure you could modify your HPWC and buy the appropriate recepticles, but I dont think you really gain anything.
I don't get it, If you are limiting yourself to 40 amps why not just use the UMC that comes with the car and save $1200?
As another poster pointed out and gave me a +1, aesthetics is the primary reason. Another reason is a dedicated wall unit frees up the UMC for traveling and also provides the security of a backup if the wall unit fails. There are manufacturers already producing wall mounted plug-in units so its not a question of no market for them.
Sure the EVSE is dumb. All the smarts are in the car where they should be.It appears this is a "dumb" EVSE. No web interface or way to schedule charge time for the best rates?
