a) the UMC has been discontinued for sale in Canada
Thanks. Good to know they have the cable already made at Home Depot. Is it in the electrical section?
Wow, did not know that. Why did they discontinue it?
Just curious: why do you want to convert an HPWC with a Model S/X connector to one with a NEMA 14-50 connector? Then to charge the car you have plug the UMC with the 14-50 adaptor into the HPWC cable with the 14-50R?Anyone connected their HPWC to a NEMA 14-50 outlet. Can you show me your wiring setup, some pictures of the connections and cables? I am interested in trying it out.
Do you mean that it is no longer possible in Canada to buy the UMC separately from the car? After all, a UMC comes with every Model S/X sold in Canada. Why wouldn't Tesla sell the UMC separately?the UMC has been discontinued for sale in Canada.
Do you want to do this simply to make the HPWC a more versatile power source?
p.s. Now that near-production versions of the X have been seen on the streets in California, I somehow feel compelled to write "Model S/X" instead of just "Model S" when discussing items like the UMC. [emoji3]
The idea is to install a NEMA 14-50 cord set on to the HPWC so that you can simply plug it in to a pre-existing NEMA 14-50 outlet, rather than hard-wiring it in. No change to the cable that goes to the car.
Mounted the UMC to the wall near my outlet and plugged it in. Works like a champ.
Shouldn't that be HPWC instead of UMC?
I wonder if they will be updating the HPWC anytime soon
JDo you mean that it is no longer possible in Canada to buy the UMC separately from the car? After all, a UMC comes with every Model S/X sold in Canada. Why wouldn't Tesla sell the UMC separately?
I have a NEMA 14-50 in the garage. I was thinking of buying a second UMC so I could leave one in the car, but a) the UMC has been discontinued for sale in Canada and b) the HPWC was only something like $100 more, so I bought a HPWC.
All I did was purchase a cord set intended for an electric range at my local Home Depot. It has a NEMA 14-50 plug on one end and bare wires on the other. I installed a cable strain relief fitting into the HPWC, ran the cable inside and hooked it up. I set the DIP switches to the position for a 50 amp circuit (40 amps delivered). Mounted the UMC to the wall near my outlet and plugged it in. Works like a champ.
Thx
FWIW, the Tesla Charging Support Team will inform you that the only approved wiring method for the HPWC is permanent on a dedicated branch circuit.
While the HPWC Installation Guide does not specifically state that a flexible power cord is not allowed, it only includes guidance for a permanent/hardwired installation.
The HPWC is a UL listed device (UL 2594 Standard) and as such the installation must comply with the manufacture installation instruction or the UL Listing is void and the equipment is therefore not acceptable to the NEC.
Also, the NEC restricts the length of the flexible cord to 12 inches when allowed, however for the Tesla HPWC the flexible cord is not an approved wiring method as per Tesla.
