Guys,
Rather than debate, this is not hard to determine for yourself, with reasonable accuracy, if you have a wall connector or even a UMC (you just will probably max out the UMC - and I think even the wall connector based on data from others):
On a cool day, but with a freshly driven battery that doesn’t need warming, with cabin interior cooled to 62 or so (use the AC!)
Plug in car.
Make sure fan speed is maxed out.
Set charge limit below current charge level.
Crack one door slightly so the screen stays on. Make sure the charging page is up for your perusal. Make sure UMC/wall connector clicks on and provides current.
Crank the heat to max using the app from outside the car.
See the peakV*A on the screen. It’ll ramp up very high (I see 32/32A from the UMC when cranking heat). I suspect you will see that the heater draw can exceed 10kW, temporarily (I see it can go as high as 7kW). Since the battery is warm for this test scenario, it’s probably reasonable to rule out battery heating as a contributor.
Of course it will drop substantially as it comes to temp (another piece of evidence that suggests battery heat is not a factor).
The baseline load is about 2A at 240V, so subtract that from the peak number... you can determine baseline load by just turning off the heat in the app. I see about 2A. If I turn on all 5 seat heaters I see 4A. So seat heaters are about 500W total.
Turn on and off the heat and also turn on AC on max if you want and cool down the cabin (you’ll find it is more efficient by about 2-3x but check for yourself)
And you can then multiply by 0.9 or 0.95 or whatever you assume the charger AC->DC conversion efficiency to be.
I’ve posted elsewhere with experiments showing the heat power use plateaus down at about 1-2kW steady state when warming cabin to 70 degrees in the shade with a 60 degree ambient.
To answer the OP’s
@DSMLVNV post, absolutely you can see significant mileage loss by prewarming the car or sitting idle (especially with climate on)! With a 1kW steady state draw, you’ll lose about 1 rated mile every 15 minutes. If it is 40 outside with no solar heating you’ll probably see more than that.
This is one major reason why winter kills the efficiency...heat takes a lot of power!
Seat heaters ~100W each at Max
Heat+Fan: at
least 7kW peak
Baseline load in idle with screen on: ~500W (this may include other loads that aren’t there when driving but I have no way to know)
These numbers can be reduced by the charger efficiency as mentioned above.
