It was probably also heating the battery, which uses a different process than cabin heating. You will also use a bunch of energy at first when it’s cold out. As the car/battery warms up, the power draw drops significantly.Excellent!. And one follow-up. I might be nuts, but I'm in Vegas and obviously it doesn't get too cold here. However, some Dec/Jan nights can get down to high 20's. The other morning, it was about 35 degrees outside where my car was parked (not in garage), I heated up the cabin for maybe 3-4 minutes only and felt like I lost a ton of miles. Was I just seeing things?
Is there a way to only pre-heat the cabin and not the battery?
I don't think it will pre-heat the battery sitting idle with cabin on. I think things need to be fairly drastic before Model 3 ever spends energy to heat battery.
And yes, the cabin heat is 2000 watts. Depending on outside temperatures it can use significant battery sitting idle in the cold.
With no wind from driving though it should use less than when moving.
While driving you have to manage fogging so you might need to run A/C and/or Mix Outside Air.
But if idle turn off A/C and turn on recirculate. Things may fog up but that will use a lot less juice.
OK, so lastly, if it's 40 degrees in the morning, which is rare in Vegas (only 2 months a year), how many miles will I lose as the car just heats up on its own as I start to drive bc of the cold weather?
I doubt you would even lose 1 mile of range with the heat on 80. Totally insignificant. Idle away!
Cabin heater is ~4.3kW.
The source is in the linked video. If it’s not correct, please share.You have your source, I have mine. It doesn't really matter for this discussion other than it is significant.
I assumed you were talking about draw while driving. Sorry. I don’t know if the car starts warming the battery when you remotely warm the car. I can tell you the following though:
310miles / 75 kWh (battery size in LR)= 4.13 miles per kWh.
The HVAC uses about 4.3 kW when heating on full according to the video linked below. That means you use 4.3 kWh worth of battery if the heater ran for an entire hour on full, which you would never do. 1/2 an hour would use roughly 2.15 kWh at this worst case rate. 4.13 m/kWh * 2.15kWh= 8.88 miles lost from the heater. In reality, the heater would on run on max for a few minutes to bring up the temp. After that maintaining your desired temp would take much less power. Therefore, you’re looking at a realistic 1-3 miles of loss from the cabin HVAC depending on the difference between starting temp and the desired.
Let's Look At Energy Consumption Of Tesla Model 3 Heater
Preheating the cabin will heat the battery as well but only slightly. The best way to to the latter is to charge it just before you leave. This morning, when the temperature was -15 degrees, I used the app to start charging the battery at 6:00am and it was fully warm and operational by the time I left for work. This takes a bit more planning but it's effective.I don’t think the user has any control over the battery heating/management.
I wish this was something they would change so we could pre-heat the battery along with the cabin.
Do you lose mileage if you are just sitting idling, for example, having a cup of coffee for a 1/2 hour, while the car is on?
