I can't find info anywhere on the % impact of passengers on the battery range of my Tesla 3. We are travelling 280ks return tonight with driver and 3 adult passengers and are trying to ascertain whether we need a recharge on the journey.
About the only way I know of estimating the impact of excess weight on the car's range would be to plug in your trip at abetterrouteplanner.com, with a driver-only trip and then re-running the trip by using the Settings/Vehicle/Extra Weight setting.
Yep, use ABRP for planning, but in general, I've found extra weight, as long as it's inside the car, to have minimal effect upon range. Generally, you're more likely to have to stop anyway, as someone is bound to want to use the toilet or get a snack or something.
How close is it with just the driver in similar conditions?
If you can make it with 10% to spare you’ll be fine with the extra passengers.
The biggest impact extra weight has is when going up very large hills it might prevent you from making the summit (since you have to lift all that weight up, which might be 15% of the vehicle weight). But you have to be cutting things really close for this to be an issue, practically speaking. (For example on 5000-foot climb, if you were targeting reaching the summit at 2% SOC, while arriving at your destination on the far side at 5-10%, you might not make it with passengers. No one does this.)
I am about to go on my first roadtrip! I am traveling from La Verne, CA to Scottsdale, AZ. There will be 3 of us. Does the Model Y take into account added weight when calculating its battery range? (I assume additional weight negatively affects the cars ability to achieve its maximum driving...
