Do you think you can post couple of pictures of your set up inside and outside and garage door closes please. I am in Manalapan New Jersey looking to install 14-50 outlet inside my garage, but the car will be outside.That’s what I’m doing, I had a NEMA 14-50 outlet installed just inside the garage door and can get the cable under my garage door with the brick inside. Going to put a little hook outside for the cable as well.
Sure, attached. I don't foresee any issue charging outdoors in the winter (although I plan to sell one of my MGB's, currently taking up space in my garage, to get the car indoors). We've had 2 tropical storms come through in the last month and no issues with 6" and 9" of rain, respectively...Do you think you can post couple of pictures of your set up inside and outside and garage door closes please. I am in Manalapan New Jersey looking to install 14-50 outlet inside my garage, but the car will be outside.
What do you do in the winter special in the snow is it OK to call being outside charging?
Thank you.
Thank you very much for the info and the pictures.Sure, attached. I don't foresee any issue charging outdoors in the winter (although I plan to sell one of my MGB's, currently taking up space in my garage, to get the car indoors). We've had 2 tropical storms come through in the last month and no issues with 6" and 9" of rain, respectively...
View attachment 708796 View attachment 708797 View attachment 708798 View attachment 708799
Thank you for the info, I’m not sure if my garage door can be programmed to stop at certain point, it’s about 22 years old and it’s a Genie. I guess I can close the door manually when charging the car outside.I did something similar. I had my electrician install a NEMA 14-50 outlet just inside the garage, where I hang the Mobile Connector. The cord goes under the garage door and hangs in a holster attached to the wall, which keeps water out of the connector end. I set the garage door mechanism to stop just above the floor so there is no pressure on the cable. Has been fine for a year so far. I had the electrician use 6 AWG in case I wanted to install a wall connector later, but the 32 amp mobile connector is fine for my needs.
Well, I had a bit of a gap where the seal on the bottom ends and the actual side of the door - so I wired the cable to the door track so it would always be in that gap. That particular door has an inoperable automatic door closer (well it is intermittent so I just detach the door from the track. My running MGB is on that side so I don't use it too much anyway. That will change when I actually move the car into that bay. I'll get it fixed at that point.Thank you very much for the info and the pictures.
How do you keep garage door from corruption the cable, my garage door is pretty heavy and slams at the end when it closes.
Got it.Well, I had a bit of a gap where the seal on the bottom ends and the actual side of the door - so I wired the cable to the door track so it would always be in that gap. That particular door has an inoperable automatic door closer (well it is intermittent so I just detach the door from the track. My running MGB is on that side so I don't use it too much anyway. That will change when I actually move the car into that bay. I'll get it fixed at that point.
