Interior trunk lights and door lock questions
Discussion in 'Model S: Interior & Exterior' started by themacs, Dec 6, 2014.
  1. themacs
    themacs Member
    san clemente, CA
    A few questions. Maybe I just don't get it or find them :)
    1) Are there lights for the trunks. When I open the rear hatch and front hatch there is no light. Is it a setting? Or simply no light?
    2) When I pull up to let someone in the passenger seat, I have to open my door so it presents the outer handle for the passenger. I know I can use the touch pad and "unlock" the doors but is that the only way other then opening the drivers door?
    Thanks!
  2. bollar
    bollar Disgruntled Member
    Southlake, TX
    1) you should have a light on the lift gate. If you have premium lighting, you'll have additional anemic lighting on the rear trunk walls on either side of the gate. It's fairly easy to replace the lights with LED arrays.
    2) no, that's it
  3. Winston
    Winston Member
    Western Australia
    I don't actually have a Model S, but I'm pretty sure putting the car in park by pressing the button on the end of the gear selector will extend the handles.
  4. CliffG
    CliffG Member
    New Jersey
    Yes, right in the liftgate - although it's not particularly bright. Don't remember about the frunk
    I just put it in park, tapping the end of the gear selector, which also makes sure the car won't move while they're getting in or out.
  5. themacs
    themacs Member
    san clemente, CA
    Tell me about the LED arrays if you will please !
    Thanks to all for the answers :)
  6. bollar
    Southlake, TX
