transpondster
82000 weird weight units are about 37200 kg. Let's assume Semi is traveling 90km/h ~56mph at 6% descentI think petit_bateau's point is that reversing the motors to actively brake, instead of regen, would generate significantly more heat (and much more quickly) than anticipated.
So I think we should look at it this way:
How much power (in KW) does it take to go uphill at a constant speed? That should be the same power (in the form of heat) that you'd need to dissipate going downhill. As long as the motors + cooling system can convert that to heat and dissipate it out into the air, then there's plenty of "braking" capacity to go downhill, even without regen.
Edit: Relying on the friction brakes to "travel" downhill is a no-no. That's riding the brakes and is a sure way to deplete your available braking reserves.
37200 * 9,8 * 90000 * ( 6 / 100) / 3 600 000 it collects potential energy at ~550 kW rate. From Elon consumption is 1,7kWh/ miles means ~100 kW energy needed for rolling and aero resistance. That means it needs to regen ~450 kW. There is no way in hell it would be able to remove 450 kW as heat
