Knightshade
Is there deterministic engineering evidence to support these statements? I'd love to see it. This thread is for engineering stuff, and so far, I've seen no engineering evidence to support the conclusion that the current system HW is not capable of L5.
I've only seen Green produce data that is assumed to come to these conclusions.
He's posted about his root access showing Tesla is using both nodes for a single instance of the entire system- because there's not enough compute to run it on a single one...and that over time the spillover to node B has only gotten worse.
They HAD run it on a single one until roughly mid 2020, then they starting having to use compute on the second node for the one instance of the whole system... and increasingly began needing to move more and more there, to the point they're about maxxed out on compute on both nodes now.
Further he mentioned (and just looking at the physical design it's obvious) that cross-node computing is painfully performance-harmful compared to being able to run everything on a single node (the cross-node connect is much slower and narrower for one thing)
None of this is even terribly surprising given Tesla has totally redone the design for FSD more than once since HW3 was designed due to hitting local maximums on the previous designs.
@verygreen is welcome to comment in more detail if he wishes, or you could PM him I suppose since he is a (vaguely) active member here.
Even Douma doesn't seem to deny they're out of compute, he just thinks they will *magic hand wave* somehow fit it all back into a single node eventually somehow with optimizing.
The CA DMV stuff, found here, page 26, shows that Tesla continues to work on L3+ features
"Please note that Tesla’s development of true autonomous features (SAE Levels 3+) will follow our iterative process(development, validation, early release, etc.) and any such features will not be released to the general public until we have fully validated them and received any required regulatory permits or approvals."
Right- and they also, specifically, say that FSDb (internally called city streets) is not L3 and will never be because it does have have an OEDR capable of it.
So the system that lacks stuff to even make it to L3, and is out of compute doing that, is insufficient HW for L3, let alone 5, is a pretty reasonable conclusion to draw.
Tesla to CA DMV said:City Streets’ capabilities with respect to the object and event detection and response (OEDR) sub-task are limited, as there are circumstances and events to which the system is not capable of recognizing or responding
They go on to conclude:
Tesla to CA DMV said:As such, a final release of City Streets will continue to be an SAE Level 2, advanced driver-assistance feature.
The FINAL release of city streets is L2, full stop, because it's not, by design, capable of more. They'll develop and release some future >L2 system (and will doubtless build on what is here now), but what we're testing in the beta (and now wide release) ain't it and wasn't intended to be.
And I'm happy to provide a video of my 2017 X working, without any material difference from perfect conditions, in rain with FSD without the windshield wipers as the hydrophobic coating allows the water to bead and thus not completely blind/obscure the forward camera.
If all the side cams remain entirely clear I'm sure that's true. Which they often, but don't always, do remain.
But that doesn't address the problems I mentioned when they're not.
Below is a recent fsdb drive in moderate rain--front visibility was fine. FSDb was not available due to bad weather anyway. Wiping the fender cams manually "fixed" it later though.
NOTE: I had the 2021 Model 3 driver fender camera replaced a few weeks ago and the car still reports that it is functioning poorly from time to time in perfect conditions. So, this demonstrates that there are separate issues which others might be experiencing that could be causing the system to not function as designed.
FWIW I had a B-pillar cam replaced under similar conditions a while back.
Now it only fails when the camera is dirty, or especially wet, or blinded by the sun-- the sun thing obviously happens in good weather but goes away as soon as the angle changes slightly.... the other 2 go away if I physically wipe the camera off (or just wait for drying in the case of wet)... which is as expected but not conducive to L5 driving with no human.
Regarding redundancy, this is not an aircraft that is inherently unstable/ needs active control. A stopped car has only other cars to worry about.
FWIW Tesla actually DID have redundant steering ECUs until the chip shortage forced them to remove it from some cars FWIW
Tesla cut a steering component from some cars to deal with chip shortage, sources say
Tesla omitted one of two electronic control units in the cars' electrical power assisted steering systems. Tens of thousands of cars are affected, sources say.
www.cnbc.com
The explanation they appeared to gave was since the most advanced public feature, FSDb is L2 only (and always will be) it's not needed....and they can also retrofit the chip back in if they do introduce an L3 or higher system in the future.
And on the original autonomy day showing HW3 they made a big point about redundant nodes in the HW3 computer with one being able to fully fail over to the other seamlessly-- something it clearly can not do today because they need both nodes worth of compute.
That said- a compute node tends to fail (or at least reboot, not necessarily completely permanently fail) far more often than say a power steering rack. And it's likely those authorities who will approve L5 systems will be expecting redundancy here--- the EU regs specifically call out adequate redundancy for the self-driving system for example.
Tack on the fact any car maker will assume liability for an L5 failure it seems likely redundancy here will Be A Thing moreso than worrying about if say a shock goes bad or something.
