iPod / iPhone / USB stick on the Roadster 2 with Blaupunkt
Discussion in 'Roadster' started by Alef Arendsen, Dec 6, 2009.
Tags:
  1. Alef Arendsen
    Alef Arendsen Member
    Hi,
    I just got my Roadster (yay!) with the Blaupunkt NAV unit and USB connector. Both my iPhone and my iPod Nano (latest gen) don't work with it. The Nano starts charging, but doesn't want to get away from the 'connected' screen and the iPhone doesn't do anything at all...
    Then, when I plug in a USB stick with some MP3s one there, it plays the music in the first directory, but nothing else. I can't skip or anything using the stereo system.
    Apart from putting all my music in the root of the USB stick, is there anything I can do to get my iPod or iPhone to play, or to play all music from the USB stick?
    thanks!
    Alef
  2. Alpine Driver
    Alpine Driver Member
    Austria
    Alef,
    welcome!
    Nice to hear that you have your Roadster.
    Which VIN do you have, and how long was your wait?
    Which country are you in?
    As for the iPhone/iPod I cant say anything because I dont own them. But I am sure that you get a response soon.
    As for the USB stick:
    Its a crappy solution.
    It seems that the USB-connection on the Blaupunkt is emulated as an external CD-Changer.
    I managed that the following solution is working: I have my mysic not in the root, but in several different folders (no Sub-folders!) on the USB-stick.
    I have to connect the USB stick BEFORE turning on the blaupunkt. When changing source, it starts to play the tracks in the first folder. By pressing the "change CD" button (dont know excactly now where, you have to experiment there), it jumps to a different folder. Must not be the next, can also be the last, etc.
    Its a crappy solution, but I have managed to play music at different folders. But I had problems when the USB stick is connected when the blaupunkt was already booted ...
  3. LST
    LST Senior Member
    Switzerland
    iPhone on Blaupunkt
    Alef
    When my Roadster was delivered, the Bluetooth interface of the Blaupunkt was not installed and i could not use the iPhone or iPod at all. Thanks to the Tesla techs Andi and Rudi everything works as it should now. With the Bluetooth you can make your calls handsfree, and play all your music over the stereo. Pairing had to be done twice, but works perfect now.The sound quality is not too bad (of course it could be better with a direct link). I'm not able to change songs / lists via the Blaupunkt though. I don't think it is possible to connect the iPhone / iPod to the Blaupunkt over the USB. Just forget the MP3 USB stick solution, sound quality is bad, and you can't really acces to all of your songs as you whish, it's quite random.
    If you got the Bluetooth, there should be a blue plastic button at the left side of the steering column.
    Best
    Lukas
  4. dpeilow
    dpeilow Moderator
    Winchester, UK
    My brother had this stereo in his last car. I remember the issue with trying to access all the tracks on a memory stick, but one thing he later said was that he couldn't use his iPod and the bluetooth at the same time. Is that the case or was he just unlucky?
  5. mpt
    mpt Electrics are back
    Warren, New Jersey, United States
    Which unit is this? Did I miss a switch from the JVC Nav to a Blaupunkt?
  6. Alef Arendsen
    European Roadster are equipped with the Blaupunkt unit and not the JVC.
  7. Alef Arendsen
    Thanks, I'll try to the Bluetooth solution then. I haven't tried it yet, will do tomorrow!
  8. Alef Arendsen
    I have number 140 out of 250 (European Signature I guess this is), color electric blue. I originally placed my reservation early September and I think I locked in somewhere end of September. Received the car, last weekend. Got my license plates this weekend (it takes about a week here).
    I'm in the Netherlands. As far as I know, there are about 7 Roadster on the road now and another 10 on the way or so.
    I'm working with Rogier Kroymans (sales manager benelux for Tesla) occasionally. We had a booth at a big fair this weekend and got quite a few people interesting, so that was cool...
    Haha, that's quite a bit of work ;-). I'll try the bluetooth solution posted above. I noticed the quality isn't that good when connecting to USB anyway. Heck, maybe I'll even change the unit all together some time in the future.
  9. Alef Arendsen
    Well, it's working now... I had the iPhone 3.0 software installed, but apparently it needed another upgrade to 3.1.2 to get it to work. Bluetooth streaming has some hickups here and there, but the quality is certainly a lot better than the USB connector!
