Sort of similar to a CD / DVD / Blue ray player tray. With that being said, I have seen plenty of those broken because people pushed them too hard (instead of pushing the button).You can push it down, without any ill effects. You just don't want to put 10 tons of force into pushing it down. The second it feels a bit of force, it will close on its own. Basically, just tap on it and it will soft close by itself.
Is it ok to manually push down the charging port door closed or not?I did this twice today.
I just got it today. But wasn’t sure. Most likely it is not recommended. It shouldn’t damage anything right?Why (are you pushing it manually vs waiting for it to close on its own)?
Well... it has a motor in it (that pops it open) so its not something I would recommend making a habit of. If it didnt close for some reason, sure (then you would put in a service request to fix it), but I personally think its a bad idea to push on something manually that closes automatically.I just got it today. But wasn’t sure. Most likely it is not recommended. It shouldn’t damage anything right?
Thank you. I feel better nowYou can push it down, without any ill effects. You just don't want to put 10 tons of force into pushing it down. The second it feels a bit of force, it will close on its own. Basically, just tap on it and it will soft close by itself.
ok, thank youWell... it has a motor in it (that pops it open) so its not something I would recommend making a habit of. If it didnt close for some reason, sure (then you would put in a service request to fix it), but I personally think its a bad idea to push on something manually that closes automatically.
Thank youI'm sure you are fine but I would not recommend if it's not stated in the manual.
Hey maybe you'll create a little regen!Not recommend! it open and close by a small motor I think, may not good for the motor if close it manually everytime.
