nayr14
Not hate. Just more involved than needed. The various aftermarket monitoring solutions cause needless drain on both HV and 12V batteries. Tesla has done everything but officially advise against the use of these. Expect that to change in the coming months as they look to block the use of these.
+1 on not installing monitoring software that constantly pings your Tesla. My 2013 S never slept until I uninstalled the tool I had which constantly pinged the car API. Now our Tesla no longer suffers from insomnia. And we save 3 kWh a day. I did install an OBDII device which passively monitors from FleetCarma
ScanMyTesla is passive and reads the CAN bus. It a extremely, extremely small draw compared to the other various systems that are constantly running 24/7. It reads what the car is sending across the CAN bus, and it only reads when you have the app open and connect to the BT dongle.
The beauty of SMT is that the community has decoded the signal addresses, allowing those interested to learn more about their cars. Battery temperature, motor power, preconditioning, HV battery voltage, HV usable capacity (the REAL measure of degradation), motor temperature, coolant pump rate, etc. The list goes on and on - I've learned a lot about how my car works with that app, 110% worth it if you're interested in the inner workings. If you have any concerns, unplug the OBD2 dongle...
For tracking, I do use TeslaMate which is an opensource tracking software which uses the API. I run that on a RaspberryPi and it doesn't drain the battery. You can read more on their GitHub page if you're interested.
