I'm a tesla lover but am seriously worried for them
I can't imagine why ... I drove down to Bath last night for a concert, 340 mile round trip, was coming home very late and Type-2 charging would have saved me 30 minutes Supercharging on the way home ...
Car park with EV charging less than 10 minutes walk from the venue ... great ... checked with Plugshare, supports CYC which I am a member of (and there's your first problem ...)
Rocked up, 4 charging bays, two charging "posts", a Freelander charging in one bay. Parked, jumped out and retrieved my (very bulky) Type-2 cable from Frunk, plugged into car, and post. Noted that the A-port was showing red-light with an "Error on port A" message, but B was green. Fire up APP, no indication that the location even existed
. Phoned the CYC support number:
"Can't find the Post location in the APP"
"No problem Sir, what's the ID Number?"
"12345"
"Thank you Sir, I've got it. What's your email address?"
"fred.blogs@..." (talking of which, I used a special one-off email address to register with CYC ... good job! otherwise anyone could use my account to charge!!")
"One of the ports is showing an error, which one are you plugged into Sir?"
"Yes, I saw the A-port has error, I'm in B"
"Right Sir, I'll start the charge now"
All this has taken at least 5 minutes from when I arrived ...
"Sorry Sir, I've got an error, I won't be able to initiate the charge for you"
"There's another post here, if I move the car to that one will you be able to start a charge on that?"
"Are you sure Sir, I'm only showing one Post there"
I wander over ... its a different brand (that I'm not a member of ...) ... I give him the ID number and sure enough "Not one of ours"
"I can help you with other locations nearby"
I'd already seen from the APP there was nothing nearby but
"OK, Thanks"
"The nearest is the Park and Ride on the outskirts of town ..."
"It's OK thanks, I've got a Tesla and enough charge to get to a Supercharger on the way home. Thanks very much for your help"
Can't fault how pleasant and helpful the chap was, but this was most definitely not an isolated incident for me. One of the ports not working has been common IME, and faffing with APP and phoning up - and that taking ages - is absolutely the norm IME.
Rocked up at Reading Supercharger. 4 bays, one car already there, all bays working. Plugged in. Another car turned up after a bit, and shortly after that the first car left. Decided because no refreshments there, and peeing in the bush was a bit
gauche, that I'd split and charge some more at South Mimms.
Rocked up at South Mimms gone midnight, a dozen bays, one other car charging. Strolled to Starbucks which was still open, after 10 minutes I was on my way again ...
Hopefully Jag drivers will never drive out of range and only charge at home ... or have enormous faith in the rollout, availability and "up-time" service levels of the coming-soon CCS chargers ...
But not for me, no thanks.
