Home Depot sells this adapter: AC WORKS NEMA L6-20P 20 Amp 250-Volt Locking Plug to NEMA 6-15/20R 15/20 Amp 250-Volt Female Connector-ADL620620 - The Home Depot
It should be perfectly safe to use because all it does is change the plug. Hot wires should be the same, and amps are the same. You will still need to buy 6-20 adapter from Tesla, but those are only $35 and ship quickly.
Yes, exactly this! @ONEDVSMOFO please just get that one. Now that the EVSEAdapters site started making realistic adapters that fit right into the Tesla mobile charging cable, and properly manage the current level automatically, I don't recommend trying to do any other multi-stage adapting with other pigtails. Just get this L6-20 one that goes right into your UMC, and it's all legit and simple and safe. There are a few other odd outlet types that Tesla doesn't sell adapters for, but EVSEAdapters does.The L6-20 is just the locking variety of the 6-20 outlet. When using it, be sure to rotate the plug slight after inserting to activate the locking mechanism. These are typical in commercial settings. Many data centers use the L6-30 plug to connect the power strips in server racks.
If it was me, I’d pickup on of these to use the L6-30 outlet. The higher cost is because they purchase a standard Tesla adapter, the plug, and then add some labor to graft the two together. This is something your grandma could use, where something like an L6-20 plug to 14-50 receptacle adapter needs knowledge to use safely.
L6-20 Adapter for Tesla Model S/X/3 Gen 2
So you express your concern about the temperature sensing...FWIW, I am not sure I am a fan of the EVSE Adapters units. I love that they are filling a market need, but I have concerns of how well they would actually sense thermal issues. My understanding is that the way they make these is to buy the Tesla unit, cut it apart, and glue the thermal sensing unit into a new connector. It is unclear if the connectors they put it in will really conduct heat well enough to be effective.
...and then you shoot it in the face.If it was me, I would buy the 6-20 adapter from Tesla and get the L6-20p to 6-20r adapter. (this would give you the option to plug into 6-20 and L6-20 receptacles with the combination of adaptors) This would have the right communication to the car about the max amp draw, so that risk is removed compared to some of the other adapter options.
That's not true, as shown above. They do remove and reinstall Tesla's actual temperature sensor into the plugs they build, which is why they are a little spendy.I’m fine with either the EVSEAdapter setup or a short L6-20 plug to 6-20 receptacle adapter and then the standard Tesla 6-20 plug. Both have a slight risk in that you’re not going to be measuring heat in the L6-20 outlet.
What is confusing about just ordering the adapter for the outlet you have? We're just recommending not trying to build one yourself.So confusing. Maybe I’ll forego this and stick to a standard outlet.
Don't you remember? You were in this thread, where John Rowell told us how this works? He works at EVSEAdapters and is the actual guy who builds these. Here's the link:
Using old AC lines for a new NEMA14-30 outlet
He removes the temperature sensing circuit intact and installs it in the adapter plugs they make so that functionality is preserved and operates the same way it does in the official Tesla ones.
Your recommendation of just using a 6-20 to L6-20 pigtail now puts the temperature sensor about 6 to 8 inches away from the outlet so that it becomes completely useless for sensing any heat from bad wiring in the outlet. So if you actually care about the use of the temp sensor, as you say you do, then you definitely should be recommending the plugs from EVSEAdapters.
