So I'm looking at Model Y lifts.
MPP has a lift that just moves mount points. This is an adequate change. However, it requires adjustable links in the rear to return camber to the rear and fix the geometry. The problem is, every single link I've seen, including the one from MPP, has a rod end in bending. They're all engineered like garbage. I don't feel like that's good enough for offroad usage or a strong speedbump hit.
Then there's the Unplugged offroad package. It's more than twice as much and involves coilovers of questionable parentage. Dual tube? Monotube? Rebuildable? They don't even have a photo of the actual suspension. What's included? No details. This does not fill me with confidence either. Spring rate? How much longer are the springs? Helpers needed? Just the coilovers or are other suspension bits included? Will I still need camber adjustment?
Our options are bad. I'd like a 3-4" lift, all said and done, with somewhat larger tires.
Did anybody actually buy the offroad kit?
