Cross posted from my blog, which has a few more photos, which are hard to transfer over.
Unfortunately, my adapter from my Roadster high power wall connector to my Model S is on backorder. I am living with the 110 connection in my house. My dryer is in the middle of my house, so there is no 220 plug in the garage, only the Roadster high power connector.
The following information might be useful for someone else with only 110 connection permanently or in a short term situation such as on a road trip with limited charging options.
Although the charging is extremely slow, I have not found using a slow charge to be a large issue. So far I have been able to take the car wherever I have needed to go without any range anxiety.
I have encountered four limitations with the 110 cable so far.
1. The cable is quite short, the model S is quite long, and the plug is in the back of the car. I think even a few more feet of cable would be a great improvement. Particularly in light of the wording in their contract
"that an extension cord should never be used to charge your vehicle."
2. The 110 adaptor plug is an awkward shape. I think it should be more "short and wide" then "long and narrow". When plugged into a high socket, the weight of the plug and wire make it difficult to keep a strong connection. The first outlet is about 3 feet off the ground. Reminds me of days when you had to travel with an adaptor plug and a transformer to switch voltage.
The connection is not strong with the two plugs and unfortunate weight distribution. I had to push it in extra tight before the car would start charging. Also because the cable is short, it is easy to trip on when walking by as there is not enough extra cable to easily drape it flat along the garage floor.
My solution for the short plug was to rearrange my garage, and put the Model S in the third bay. The car has been exiled to the back of the garage. The third bay has storage cabinets and a shelf with two sets of outlets. In this configuration, I can rest the plug on the open shelf, and get a much tighter seal.
3. While in this new configuration, I did have the fuse trip during one day of charging. I did not notice this and lost a lot of charging opportunity time. I had driven quite a bit the day before, so this was unfortunate. So far, the fuse has only tripped once, but I have only had the car for one week, so time will tell. But I can easily monitor this from the wonderful Tesla App. Would be even nicer if the app sent you a text message when power was interrupted.
4. I would also prefer to not use electricity during PGE peak periods, so my car will cost more to drive until the adaptor arrives.
