Locking a Passenger Inside....On Purpose.
Discussion in 'Model X' started by bugZPDX, Jan 14, 2017.
Tags:
  1. bugZPDX
    bugZPDX Member
    Oregon
    I've searched the forums and elsewhere but I can't seem to find an answer as to how to lock the car with a passenger inside.
    The other night two of us went to the store. I decided to stay in the car but wanted the doors locked. I kept the fob and used the lock feature on the touchscreen to lock the car. I assumed that when the driver returned I would have to unlock the doors for them but they simply pushed the rear hatch button/release thing and the back opened up. I hadn't noticed them even walking up to the car and it really startled me. They then came around and opened the driver's door with no problem. Is this expected behavior?
  2. TacC
    TacC Member
    East Bay, CA
    #2 TacC, Jan 14, 2017
    I assume so because you used the key to lock the car, which is a behavior expected for someone outside of the car.
    Try locking with the touch screen. That is a different behavior and matches with someone aiming to protect people, rather than possessions. It can be done while driving so I assume it overrides any unlock with the fob in range.
  3. Andyw2100
    Andyw2100 Supporting Member
    Ithaca, NY
    The OP stated that he/she did lock the car by using the touchscreen.
  4. neroden
    neroden Happy Model S Owner
    Ithaca, NY, USA
    The passenger can always leave the car, whether it's been locked or not. This is a safety feature.
    It's a little interesting that the car stays unlocked after the passenger leaves, though. Do you have "walk away lock" turned on?
  5. bugZPDX
    bugZPDX Member
    Oregon
    I want to stay in the car with it locked and don't want anyone outside of the car without a fob to be able to open the doors.
  6. Andyw2100
    Ithaca, NY
    Silly question, but any chance the car behaved as it did because the person returning to the car while you were locked inside it also had a fob with them?
  7. fancycar
    fancycar Member
    San Diego, CA
    Our car stays locked with us inside if we lock it from the touchscreen, or if it locks itself because we were driving, just as you describe doing (touchscreen). We have to unlock by touchscreen or by pushing park twice.
    Hope the helps!
  8. bugZPDX
    bugZPDX Member
    Oregon
    I kept the only fob with me and locked the car from the touchscreen.
  9. bugZPDX
    bugZPDX Member
    Oregon
    Seems like I did the correct thing but the car did not :) I'll bring it up to service when we take it in soon. Thanks everyone for the replies.
  10. S4WRXTTCS
    S4WRXTTCS Active Member
    Snohomish, WA
    So let me get this straight.
    Here is a car that has biodefence mode for the zombie apocalypse, but you can't lock EVERY entry while inside the car.
    I'll have to test this on the Model S because it seems like a bizarre weakness that the rear trunk/hatch can be opened when the car is locked from the touchscreen.
  11. bugZPDX
    bugZPDX Member
    Oregon
    Yep! And I completely agree. I'm hoping it's just a mistake and easily fixed.
  12. S4WRXTTCS
    Snohomish, WA
    I think it's a bug.
    Which firmware version?
    I don't see any reason why one car would act different than another unless it was a different firmware version. The other poster also didn't state specifically that he/she tested the rear hatch.
  13. bugZPDX
    bugZPDX Member
    Oregon
    We have 2.50.180
  14. outie
    outie Active Member
    SoCal
    I just went to the garage to do the experiment.
    I opened the driver's window, left the key inside, touched the screen to turn on the screen and music started playing etc., touched the Lock icon on the top left corner.
    All doors remain locked from outside, including the trunk.
    I am not sure what happened in your case. Can you consistently replicate it?
  15. hacer
    hacer Member
    Clarksville, MD
    But nobody was inside the car? It could cause a different behavior.
  16. Andyw2100
    Ithaca, NY
    In the situation in the OP, here's another possibility.
    Had the driver left something on the driver's seat, and was the car not off, but rather left in park? I could be wrong, but with the car in park I believe someone pressing on the door handles would cause them to present. (There's a chance I'm wrong about that, and none of this explains the hatch behavior. I'm just throwing things out there.)
  17. bugZPDX
    bugZPDX Member
    Oregon
    Unfortunately/fortunately? our car is getting XPEL so I can't try it again quite yet.
  18. bugZPDX
    bugZPDX Member
    Oregon
    There wasn't anything on the driver's seat. We pulled into a parking spot, the park button was pushed, I held on to the fob in the front passenger seat, they exited the vehicle and manually closed the door, I pushed the lock button on the touchscreen and listened to music, kept the heater on, etc.
    Maybe that's where I'm confused? Was keeping the screen active by skipping songs and changing artists the reason the doors were able to be unlocked? I'd like to think I can sit in the car and have music and such and still be locked in. As soon as we get our car back (feels like it's taking fooooooorever) I'll try to replicate.
  19. krazineurons
    krazineurons krazineurons
    Redmond, wa
    Apparently in our X, I had the fob with me and I was not near the car. As the passengers alighted using the falcon doors the car raised an alarm, I had to fumble on the fob to turn off the alarm. I had all the locking settings enabled.
  20. wycolo
    wycolo Active Member
    WY
    Or, driver absentmindedly drove to location not noticing hatch was half-latched (graphically open on screen) - assuming hatch can indeed be half-latched.
