I noticed I’ve been losing estimated range ever since I started daily charging to 50-55% and arriving home with 23-30%
While I havent seen any tendencies to this, I can asure that you do not loose real range.
It might be possible that the BMS get off track, and show less range but the battery itself lives better than ever at these low SOC ranges.
I always need longer drives at least ones a month so I havent stayed low for that long.
I might have been ~ 1.5 months at 55% and below without any higher charges but these have never showed lower range on my M3P. It has regained range by being low long time.
My MSP might “loose” a half percent/0.5 kWh after one month low. (But it always regains 0.5-1kWh that was lost from high SOC / supercharging / larger cycles.
This “recovery is probably real capacity recovered, and the possible loss after ~ 1 month would problably be the BMS getting slightly off.
2 months ago I was showing 145 miles of range at 50% charge, then it was 144 miles, now today it’s 143 miles, this wasn’t happening when I was charging to 70-80%
Car hasn’t been charged to 100% in a year, I might try it and see what happens and use my 100% charge over 3 days
Reading various comments on Reddit there seems to be a trend of people with low degradation charge their cars to 100% atleast a few times per year mostly for trips, but I haven’t been on any trips to charge to 100%, people that never charge to 100% seem to have more degradation
I am quite sure you have less degradation from this year at 55% and below than you would have using the usual 80%.
We know that battery degradation is very predictable and does happen in a controlled rate from factors we understand.
Low SOC will preserve the battery.
You could perform a BMS calib if you like, but that only will restore displayed range, not the real drivable range. Guess you know how to perform a BMS calib?
No sentry, no perping in the app meanwhile.
The car
needs to sleep at different SOC to measure the open circuit voltage (no load on the battery goves the perfect SOC reading).
The BMS would need to see high SOC and low SOC. You could do 90-100% SOC and let it sleep for three hours or so, and also single digit SOC for three hours or so as well. Several times might be needed and it could be good with sleep at 70-80% as well. (This means inducing slight extra degradation to reach your goal of a BMS calib)
