Check your gap between windshield and ceiling glass. If its large...that is probably where the noise is coming from and you should buy the rpm tesla wind noise reduction kit or the cheaper knockoffs as linked to above.
I went ahead and bought the wind noise reduction kit...with the door noise reduction kit from rpm tesla, just to try out. I didn't previously notice abnormal high speed wind noise...but it was cheap enough to try out to see if there would be a difference. But...my gap was too small and I couldn't even install it so I sent it back. I most likely don't have a "wind noise" problem, which...I"m happy about of course.
Since all panel gaps on teslas are not created equal...I assume you have a larger than normal windshield to ceiling glass gap.
