Just got my P3D+ back with T-Sportline springs installed. Ride quality is very similar to stock springs though I didn’t drive too much after picking the car up.
Very happy to get rid of the unsightly gap and no reverse raking going on either. The measurement is equal at the jack points.
Beautiful! Can't wait to get my springs!
Do you think any kind of camber kit will be needed for correction? I want perfect camber, if not, damn near perfect. I think the drop is mild enough they aren't necessary but didn't know if you gathered any data/numbers on camber after installation on these.
What’s “perfect” camber? 0 degrees? Even stock it’s not 0 degrees. My camber post drop is 0.9-1 degree negative which is actually pretty darn good for both performance and longevity reasons.
Just put UP super performance springs on my Performance model. Front wheel wheel is 27” from the garage floor, the rear 27 3/8. Noticeably better ride quality. Feels tight and firm; BMW ride quality. No jiggles, rattles, etc. Cornering is flatter. No increase in noise or harshness. Definitely worth the time and money. I did the install myself. Not the toughest mechanics job I’ve done (pulled a VW GTI transmission out to replace clutch; that was a bitch to do in a garage). The improved handling, ride quality and aesthetics made it worth the cost in time and effort.
There's no camber adjustment at all in the rear, so you can't "correct" anything without a "kit".
Very nice to hear! Great to see the comfort increases, and jiggles & rattles are diminishedGets me even more impatient for the KW V3 upgrade.
Check out the @MountainPass coilovers - they’re KW spec’d for the 3
Huh? Who told you that?
The Model 3 Service Manual shows 3 places to adjust camber in the rear: Lower aft link to knuckle bolt, Lower aft link to subframe bolt, and Upper aft link to subframe bolt.
MPP Arastradero Model 3 Rear Camber Arms | Mountain Pass Performance
" The OEM suspension does not allow adjustment of rear camber."
Maybe Tesla has added some eccentric bolts in the meantime, but mine doesn't have them. Either that or the service manual is just referring to slop, which can be used to make minor adjustments.
Zero noise or squeaks with Eibachs; 4,000 miles on them.
Which Eibach springs did you get? I’m thinking about getting the Eibach Pro Plus Suspension Kit with the sway bars.
