K kauzwell New Member Nov 25, 2023 2 0 chicago Nov 25, 2023 #1 Nov 25, 2023 #1 Can you fit a 255/45/20 tire on a 2023 m3p looking to get some winter tires and found a used set just want to make sure they will fit
G gearchruncher Well-Known Member Sep 20, 2016 5,140 7,214 Seattle, WA Nov 25, 2023 #2 Nov 25, 2023 #2 No, nowhere close. 255/40/20 is 29.0" in diameter. Stock tires are under 27". This will run into the control arm upright in the front. Reactions: mpgxsvcd
M mpgxsvcd Active Member May 16, 2022 1,232 1,529 Raleigh NC Nov 26, 2023 #3 Nov 26, 2023 #3 kauzwell said: Can you fit a 255/45/20 tire on a 2023 m3p looking to get some winter tires and found a used set just want to make sure they will fit Click to expand... Did you mean 255/35/20? That may not fit but at least it would be close. 255/45/20 isn’t remotely close.
K kauzwell New Member Nov 25, 2023 2 0 chicago Nov 27, 2023 #4 Nov 27, 2023 #4 gearchruncher said: No, nowhere close. 255/40/20 is 29.0" in diameter. Stock tires are under 27". This will run into the control arm upright in the front. Click to expand... Thanks for the help
